Again with the super steep a seat angle... Bike looks fine otherwise.
Re: Let's see your ride! [thugbuster]
Post deleted by ttx_tri
Re: Let's see your ride! [ttx_tri]
Re: Let's see your ride! [cloy]
How did you paint your Speedbox?
Re: Let's see your ride! [tyme]
Just had a friend paint it using Trek colors.
Scuff the box, apply white paint then apply Trek Viper red paint. Clear coat and then ride :)
Owner of a few Speed Concepts since 2011.
Re: Let's see your ride! [beavertriathlon]
They may be older, but they're not any slower! Couple classic Cervelo's:
Just built up this new-to-me P4. Went 1x, added the Torhans bento box and Tririg OmegaX, still dialing in the cockpit and fit.
The P3SL has served me well over the years, soon to be relegated to full-time Zwift duties.
Re: Let's see your ride! [wthecoyote]
How did u do the bento on the P4?
Re: Let's see your ride! [Fishbum]
I don't know how he did it, but I attached an X-lab one to my Slice by putting a single layer of 3M paint protection film (go to auto-body and buy a small sheet- $5-10 most if they don't just give you a scrap), put on the top tube only where the bento goes, then get Gorilla Glue brand double side sticky tape to attach bento to paint film.
I can pick up the bike by the bento. Can remove if ever wanted.
But obviously bosses are nice too, lol.
Re: Let's see your ride! [Emma'sDad]
Pics?
It's quite strong, but not permanent. I let it sit for a while (week?) and then picked the bike up by the bag, so it's not going to come off until you want it to. BTW, DO NOT USE THAT GORILLA DOUBLE SIDED TAPE ON YOUR PAINT. Put it on top of the paint film. You'll likely pull your paint or carbon apart if you attach to paint.
Nice
Re: Let's see your ride! [jrielley]
I think I used two rows of tape so that it was held tight right up to either side edge vs. one down the middle.
Pretty much the same solution as me, just using 3M molding tape instead of the gorilla glue brand. Once I have everything else dialed in I plan to add toptube bosses following the Tririg method: http://www.tririg.com/...rage_Bosses_Tutorial
I have done similar, but modified my bag to have a flat carbon base. My top tube is flat topped and has a satin black vinyl patch on it where the bag sits to act as a sacrificial barrier for the paint. Using the same (thick) 3M VHB tape as what the GoPro mounts use as it helps to take up any slight irregularities.
Just uploaded some pics : https://instagram.com/p/BggHetojokg/
WD :-)
WD :-)
Re: Let's see your ride! [WD Pro]
Here are my two ladies
Re: Let's see your ride! [Stickman17]
Photo Credit: Jay Prasuhn
Frame- 2018 Canyon Speedmax SLX
BB- Ceramic Speed
Gruppo- DA 9150 Di2 w/ Ceramic Speed Oversized Pulley Wheel System
Cranks- DA9100 / 172.5 / 54/39
Powermeter- Garmin Vector 3
Bike Computer- GarminEdge 520
RaceWheels- FLO Aluminum Clincher Disc & FLO 90 Aluminum Clincher
Tires & Tubes- Continental Attack & Continental Force w/ Vitorria Latex Tubes & Orange Seal
Race Skewers- View Speed Skewers
Training Wheels- HED JET 5+ w/ Gatorskin Hardsheel Tires
Saddle- ISM PN 3.0
Cockpit- 3T Cycling
Pedals- Garmin Vector 3
Shoes- Scott Road Team Shoe (Training) & BONT Zero + (Racing)
-Brad Williams
Website | Twitter: @BW_Tri |Instagram: @BW_Tri | Strava | Co-Founder & Coach at: KIS Coaching
Team RWB Ambassador | Deals & Discounts from Sponsors
Supported by: Clever Training| Kiwami Tri | Precision Hydration | | blueseventy | ISM | Canyon| Ceramic Speed
2004 P3 650c. Finally got around to upgrading the stock cockpit and brake setup to something a little sleeker. She comes in at 17.8lbs in Sprint/Olympic mode. BTW I'm the original owner going on almost 15 years later.
Re: Let's see your ride! [Z.Andreski]
very nice. Love the P3.
Swimming Workout of the Day:
Favourite Swim Sets:
Training Plan / Log
Re: Let's see your ride! [JasoninHalifax]
Re: Let's see your ride! [triguy86]
Custom carbon. Pretty cool and something you don't see much of. Parlee and Calfee are about the only companies that come to mind.
Mostly done with the build, still experimenting with some different bars so I haven't cleaned up the front end perfectly yet. Also, still playing around with different saddles, but I actually like the one it came with (pictured here). It's been a great ride so far!
