jmjtri wrote:
Thomas Gerlach wrote:
jmjtri wrote:
Please, for the love of god, do not bring weight into the discussion of rim tape/strips. Shaving your 5 o'clock shadow makes more of a weight difference. And cotton rim tape like Velox is hands down the most reliable option. It doesn't slide around at all and doesn't have any edges than may slice the tube.
Tape-something with adhesive
rim strip- literally a circular piece of plastic that you stretch onto the rim.
I have shaved my 5 o'clock shadow, I have also weighed my head hair after cutting it. The reality is that no, there is quite a bit of difference of weight. Maybe you have had success with Velox. That is fine. But why are you trying to argue against Stans rim tape. Are you a Velox rep or something. Honestly IMHO you are doing people a disservice on here by recommending it.
I don't know what product you think I am recommending and I honestly don't know if you are reading my replies. If you want to debate the reliability of Velox that is one thing. But both Velox and Stans Rim Tape have edges. Stans is thinner, making it easier to mount difficult tires on the wider rims. It is also lighter. Why would you not go with something thinner and lighter given these benefits?
How am I doing people a disservice by recommending one of the top rim tapes on the market? You're literally preaching for people to buy tubeless rim tape. I have no idea why you would use tubeless rim tape if you have no intention of running tubeless. And yes, both have edges. But there's a big different between an cotton edge and a plastic edge. Oh, and rim tape thickness really has nothing to do with being able to fit narrow tires on wide rims. The tube is not the limiting factoring in that scenario, but the tire itself.
You are doing a disservice because the prevailing wisdom of the most experienced on the board is don't use Velox because it is not as reliable as other options and offers no benefit over say Stans tape. Talk to guys like Tom A, Rappstar, or JoshAtSilca, and I am fairly confident they will recommend what I am recommending and for similar reasons. I have mentioned numerous times the benefits of tape but you seem to ignore dismiss them. I answered your question, can you answer mine. Are you a Velox employee or something??? Not sure why such a close-mind. I have used Velox, I have used cotton-based striped, I have used veloplugs, I have used veloplugs with electrical tape layer. I have used plastic based strips. At the end of the day after years and years of using Latex I have decided that Stans/Silca tape is the best option. I would be curious. Have you ever tried tape?
Again at the crux, you seem to be hung up on the fact that that it is tubeless rim tape. As others have indicated there is nothing special about this tape. This tape has been around before tubeless was even invented. What you have is a smooth tape, that is thin, light and reliable. Again vs Velox:
1) Lighter - 20 grams is 20 grams
2) Thinner - I don't understand your argument. The tire sits on the tape. The thicker the tape the harder it is to get the tires on the rims. Do you have a wide rim? Have you tried to get say a Vittoria Corsa Speed on the Rim? The Corsa is one of the hardest if not hardest race tires ever to get on rims. Specifically rims like the Enve 7.8 or HED JET+. It is a real struggle. A thinner tape makes it easier as it doesn't raise the tire up as much. I am sure someone else can explain this better.
3) In regards to reliability. The tire bead itself sits on edge of the tape. The edge should haven't anything to do with it. Now velo plugs where the edge is inside the rim where the tube is I agree leads to decreased reliability.
Save: $50 on Speed Hound Recovery Boots |
$20 on Air Relax|
$100 on Normatec|
15% on Most Absorbable Magnesium Blogs: Best CHEAP Zwift / Bike Trainer Desk |
Theragun G3 vs $140 Bivi Percussive Massager |
Normatec Pulse 2.0 vs Normatec Pulse |
Speed Hound vs Normatec |
Air Relax vs Normatec | Q1 2018 Blood Test Results | |
Why HED JET+ Is The BEST value wheelset
