Tom A. wrote:
bootsie_cat wrote:
SRAM doesn't make clutch derailleurs for their road type derailleurs-
So no Red...for wide range cassettes. Aaah, "not so fast, my friend"...the SRAM 10sp MTB derailleurs have clutches AND are "exact actuation" (AKA, 1:1 pull ratio) and so they work perfectly fine with both 10sp and 11sp Red shifters. (It's the 11sp SRAM MTB derailleurs that went away from 1:1)
I'm using a GX10 rear derailleur on my Fuji Jari with 10sp Red shifters, Force front derailleur, 53-39 Quarq Cinqo crankset, Sunrace 11-42 cassette.
My buddy's Stinner Refugio is set up with the same GX10 rear derailleur, 11sp Red shifters, Yaw front derailleur, 52-34 110bcd crankset, Shimano 11-40 cassette. As he likes to say, he has "alls the gears" ;-)
Both setups work awesome...although the extra wide spread on the Stinner's chain rings requires quite "exact" positioning for best performance.
It's still possible to mix and match somewhat these days...
You're welcome ;-)
Thank you for talking some sense into this thread. It sounds like a lot of posts so far are just regurgitated from other threads and reflect very little experience.
One thing I would like to throw into the conversation is to look at gear inches, not gearing. A 38-40 mm tire is going to give a wheel diameter almost 5% bigger than a 25 mm. A 50 chainring on a 25 mm tire becomes a 48 chainring on a 40 mm tire. If Ted King maxed out at 119 gear inches and goes all the way down to 28 gear inches, I doubt many of us need to get much over 100 gear inches on a gravel bike.
Genuine question from somebody that respects your contributions: How much are you and your buddy hitting the 53/52 ring and dropping to the 11 or 13 cog (much above 70 rpm)? The gear range on that Stinner is incredible and definitely at the max of possibility with those components. If the 52 x 11 or 52 x 13 aren't being used though, it's essentially a 13 speed drivetrain. Maybe 14 if he's consistently riding 25 mph at a lower cadence. I'm 100% for making a bike your own and getting "alls the gears" but that setup seems a little complicated for the rest of us.
I know I'm making a big assumption that the 11 and 13 isn't getting used, but if it's not, the 52/34 x 11-40 setup equals a 365% range due to a couple gears being too tall to use. What's the range of an 11-40 cassette on its own? 364%.
If you're going to ride with the same 'gaps' in gearing, I would think that 1x could be fairly appropriate for others in a similar situation. Less weight, easier maintenance, The enginerdiness of you and your buddy make me *think* you have thought this through and know all that, so this is more for other readers.
