Just read this on the Cycling News/Bike Radar article:
Quote:
However, when developing the wheel, ENVE found that the bead stiffness on a tubeless-compatible road tyre was putting enough pressure onto the rim that the wheel moved out of dish.
ENVE has eliminated this problem using a combination of 'laminate design and tooling offset', meaning that when the tyre is installed and inflated, the wheel moves into dish. Whether or not different tyre pressures could affect the wheel dish is unclear.
Surely that can't be as bad as it sounds?! What if I wanted to run a normal tyre (i.e. non-tubeless) that has a normal bead stiffness? Is it going to be completely out of dish?!
Either way, I can't afford one and nor am I fast enough to benefit from one apparently! :D
