Excellent. Tires/tubes are a passive equipment choice that let you save watts no matter whether you're in a pack, off on a solo breakaway, or trying to bridge up; whether you're coasting downhill, climbing a hill, or cornering hard in a crit; whether the wind is blowing or it's calm; whether you're sitting up or in the drops. The savings may vary according to speed or the road surface but the savings (compared to a crappy set of tires and tubes) are always there. Whether those savings are enough to determine the outcome of a race is a separate issue from whether those savings exist.
The same thing applies to frames.
Yes & no on both tires & frames, however the above arguments are being made in a bubble, and not in a real-world situation. For example, if you were to simply look at the raw data for a tire's rolling resistance, you could make an argument that a certain set of tires is the "fastest", and while that may be technically true based on the sole criteria of rolling resistance, that doesn't make it the fastest tire overall---depending on the application (especially in road racing & crits). I'm not going to dig it up, but I've seen tests showing that the Michelin Pro 2 Race was one of the "fastest" tires out there: you couldn't pay me to put those on my bike in a crit. Ditto for most of Specialized tires in the late 90s/early 2000s---just hard as nails rubber.
What is faster: the tire that gives you ultimate confidence in a crit/road race/descending, allowing you to take corners at maximum speed or the tire that in a lab--in a straight line--is the "fastest"?
The same holds true for frames: I have ZERO doubt that Cervelo's S5 is more aero than my Parlee. However, simply based on the geometry alone, there is no way--for me--that it is "faster" in a road race/crit, and especially climbing & descending, and that is what matters to me. All the Cervelo fanboys here on ST seem to get their panties in a bunch whenever someone laughs at Cervelo's claims of aerodynamic superiority, but bike frame aerodynamics, in 99.9% of crits/road bike racing (non TT), DON'T MATERIALLY MATTER.
If it did, we'd be seeing A LOT of near pros showing up with TT helmets & deep dish wheels to road races, hoping to "save" those extra few seconds.
Or maybe Cervelo's marketing department hasn't thought of that yet?
____________
"There are two novels that can change a bookish fourteen-year old's life: The Lord of the Rings and Atlas Shrugged. One is a childish fantasy that often engenders a lifelong obsession with its unbelievable heroes, leading to an emotionally stunted, socially crippled adulthood, unable to deal with the real world. The other, of course, involves orcs." John Rogers
____________
