No looking straight at the front of the bike so you can see how much it sticks out from frame
Re: Cervelo P-Series frame triangle storage solution [ttweapons]
ttweapons wrote:
Like this? Now available in both 56 & 58cm frames by the way, the others are in production.Can you make one for size 51? I would definitely buy one. I think more people out there ride 51 & 54, not 56 & 58.
Re: Cervelo P-Series frame triangle storage solution [s13tx]
48, 51 & 54 are all underway with people who have reached out. If for some reason they stop getting in touch to assist I'll DM you to help get a 51cm model ready. 56 was done first as that's my size so was easiest to prototype on.
As for a front on photo, sure, here you go - it's the same width as the bottle so doesn't stick out further than that, hence why it's kinda hard to see it. But as you asked for it, here it is!
Rob
https://timetrialweapons.com/
Custom bike storage.
Rob
Thanks. So bottle and box both seem to align with (and not stick out from) the frame?
Re: Cervelo P-Series frame triangle storage solution [DFW_Tri]
DFW_Tri wrote:
Thanks. So bottle and box both seem to align with (and not stick out from) the frame?Kienle has a similar storage box on his Scott Plasma(last pic). Tim O'Donnell and Frodeno use this bottle as well, so you can tell it's pretty aerodynamic. I like it better than a regular round bottle for sure.
My 2c, get the bottle whether or not you want to use our storage box - if you're going to have a bottle on your downtube anyway this seems by far the most aero option. As the post above suggests, it's widely used by many pros.
The box conforms to the bottle so if you're OK with how the bottle fits I don't see you having further issues as the width is the same for the storage box. We've even matched up the dimples with how the bottle is designed so it flows seamlessly together, but if aero is everything for you then scrap the bottle and storage all together.
Rob
Rob
DFW_Tri wrote:
Yes I’ve seen that but that’s a different frame.I have 2015 P2(white & blue) and this bottle is the most aerodynamic, compact and functional bottle you can buy.
Grip is good and it locks in really well, so you will never lose it.
It’s known for randomly squirting/poor nozzle....what’s your experience?
DFW_Tri wrote:
It’s known for randomly squirting/poor nozzle....what’s your experience?Not at all. I have two bottles and both of them are good. I have to squeeze and suck at the same time to drink, so no leak at all.
I love this bottle.
ttweapons wrote:
Fellow P-Series owners, After years of no suitable bottom bracket storage system emerging for my P3 I decided to go ahead and make my own.
The CBE model above looks great, but I didn't want to lose the ability to carry a bottle - I like the Drag2Zero concept, but it's not available for the P3 and I felt it could be more aero and the entry mechanism less fiddly. This version fits my 56cm frame perfectly and I am currently working on a 58cm model to be available in the next month or so. If you have a different size frame I can easily adapt it for you by sharing a test strip to use on your bike to guide the measurements.
I comfortably carried an inner tube, CO2 and tyre lever in this and have tested it in a sprint and 70.3 Weymouth last year (pretty awful conditions, so a good test).
The unit is 3D printed and can be shipped on demand at https://timetrialweapons.com/ - the cost is largely that of the materials and printing - this is not mass produced!
Pics below and a video of installation here: https://youtu.be/IALfZK_LvGs
Nice work, very clean design. You did what I just didn't have time to work on. What software do use to design?
Yann
http://www.custombikexcessories.com
I’m in for a 51 as well (for my gf). How does the flat kit lid stay closed?
Re: Cervelo P-Series frame triangle storage solution [GreenPlease]
GreenPlease wrote:
I’m in for a 51 as well (for my gf). How does the flat kit lid stay closed?Pics show all the details and I think design of the lid is pretty clever.
https://timetrialweapons.com/...-bracket-storage-box
There is also an assembly vid here: https://www.youtube.com/watch?v=IALfZK_LvGs
Where you can see the closing mechanism several times. I ride with it regularly on poor road surfaces, no issues thus far!
Rob
Rob
ttweapons wrote:
There is also an assembly vid here: https://www.youtube.com/watch?v=IALfZK_LvGs Where you can see the closing mechanism several times. I ride with it regularly on poor road surfaces, no issues thus far!
Looks like an awesome product. Apologies if this has been asked already, but will this fit a 2016 P2 as well? My understanding was that the P2 and P3 frames are identical, but just want to confirm. I think I have a 58, but need to confirm that as well and will order as soon as I do.
Re: Cervelo P-Series frame triangle storage solution [Traphaus]
Hi, yes my understanding is you're correct although we've not had anyone with a P2 order yet to be super sure which is why I didn't explicitly state that on the site.
If you do order and for some reason it doesn't fit obviously would be happy to do a return / refund.
Rob
Rob
Rob
Rob
ttweapons wrote:
Hi, yes my understanding is you're correct although we've not had anyone with a P2 order yet to be super sure which is why I didn't explicitly state that on the site. If you do order and for some reason it doesn't fit obviously would be happy to do a return / refund.
Rob
OK, cool. I'll confirm my frame size, order tonight and will follow up on the fit.
Re: Cervelo P-Series frame triangle storage solution [yannb]
hi, is the file still available for purchase ? i tried the link and it didn't work
Re: Cervelo P-Series frame triangle storage solution [wishtue]
wishtue wrote:
hi, is the file still available for purchase ? i tried the link and it didn't workNot sure what link you are referring to. I don't sell the files for any of my products. I only sell the boxes themselves. What bike and size are you looking for?
Yann
yannb wrote:
Hi ktm520 I've posted the 3d stl file for my 54cm Cervelo P5 on cgtrader, https://www.cgtrader.com/...-p5-rear-storage-box. You can purchase the stl file for $30.
Yann
Saw this link and tried clicking it :)
wishtue wrote:
Yann
Are you still producing the integrated storage box for the P3?
Your website is down...
Thanks
Thanks
Re: Cervelo P-Series frame triangle storage solution [ejd_mil]
ejd_mil wrote:
Are you still producing the integrated storage box for the P3? Your website is down...
Thanks
you can order the bottom bracket box here: https://custombikexcessories.com/...-bracket-storage-box
and or the rear box here: https://custombikexcessories.com/...2p3-rear-storage-box
Radsport-Ibert also sells the combo storage box/aero bottle.
https://shop.radsport-ibert.de/en/aerotoolbox/cervelo/
Will there be options for bikes other than a 54 for the bottom bracket box?
I have a different size P series but I’d love to grab one of these storage boxes. I purchased the rear storage box after I helped you with sizing/measurements.
Just hoping this becomes available for other sized P series.
Thanks
Thanks
