RChung wrote:
These methods work best if you can get a wide range of speeds/powers not only within a lap but also across laps, and if it's too steep and you need to brake at the ends then you'll be less inclined to hit high power on the downhill part. (If you always coast at zero power on the downhill part, then all of the downhills are going to be identical, so you don't get any extra information from additional runs -- that's not bad per se, but it's inefficient and a waste of time).Even the downhill bit has enough flat and a dip that it's not a zero power segment. however, there is a good bit of elevation loss from the crosswalk to the back of the roundabout that would require hard braking from speeds 24-27mph.
My YouTubes
