mvenneta wrote:
I dunno.
I think I’m feigning for more calories. TP says I’m burning ~1000cal / hour and I’m only consuming 400. I feel hungry, not that I need to chew.
Is there a point when you need to eat more calories or is it all about carb consumption ?
I am planning on trying 160g carbs this weekend , but don’t expect that little bit of extra is enough
Remember, at an intensity that you can sustain for 4+ hours you are burning ~60% calories from carbs, the balance from fat. You only need to replace the carbs. No matter how lean you are, you have more than enough fat...it does not need replacing. So, you are really only looking at a net carb deficit of ~200 cal / hr or so. That's sustainable for ~8 hrs before you are approaching depletion.
On the other hand.... How often do you need to do 4+ sustained efforts above you maximum replacement rate? Are you getting any training / performance from it? Or would a different approach be better? Finishing ~800 calories depleted is manageable, but much more than that probably risks extended recovery requirements that might compromise downstream training. Could you gain the same training benefit from 4-6 hrs
at your replacement rate?
