I've gone sockless in my Skechers Razor 2's for my last two tri's and some 5k's. No issues. That is not the current model of the razor, and I can't speak for what the new one is like.
Awesome - just ordered a pair of the Razor 4 to try. The upper looks like it has minimal seams so hopefully is a good option.
I've used Skechers before and was always a huge fan (not sure why I strayed from them...).
I recommend wearing slip-on sneakers, which I have been wearing for the past year. Skechers men's equalizer persistent slip on sneaker is designed in such a way that you can use it for your workout activities as well as in your daily life. It has comfy cushioning and a flexible design that will not harm or damage your feet. You can check it out; it is available at an affordable price at the MCL online store.
I have flat feet so like shoes with some stability. I used to race in Saucony Fasttwitch, but have switched to Asics Noosa Tri because my old legs like a little more padding. salmon - not because I'm a fish
Use to run in Zoots, and although they were designed as sockless they still rubbed and chafed a lot of people. Now running in Nike Vaporflys (which you indicated you didn’t like), but the point is that most shoes will have some rub points. I’ll test out a shoe sockless for a one or two mile run and determine the rub points. Then I lube the area (body glide) and test them again. Try it on a current pair of your favorite shoes and see if this alleviates the friction areas.
