Sockless shoe recommendations?
What shoes these days are decent for running sockless for sprint and oly races?
Need a smaller heel drop as well (4-5mm).
Re: Sockless shoe recommendations? [blueapplepaste] [ In reply to ]
Maybe not the fastest shoe out there but I find the Nike Men's Zoom Fly 4 incredibly comfortable sockless for up to half marathon racing.
Scott
Re: Sockless shoe recommendations? [WiScott] [ In reply to ]
Scott
Appreciate the recommendation, unfortunately the Nike's have too much heel drop for me.
I've gone sockless in my Skechers Razor 2's for my last two tri's and some 5k's. No issues. That is not the current model of the razor, and I can't speak for what the new one is like.
Re: Sockless shoe recommendations? [trislayer] [ In reply to ]
Awesome - just ordered a pair of the Razor 4 to try. The upper looks like it has minimal seams so hopefully is a good option.
I've used Skechers before and was always a huge fan (not sure why I strayed from them...).
I recommend wearing slip-on sneakers, which I have been wearing for the past year. Skechers men's equalizer persistent slip on sneaker is designed in such a way that you can use it for your workout activities as well as in your daily life. It has comfy cushioning and a flexible design that will not harm or damage your feet. You can check it out; it is available at an affordable price at the MCL online store.
Scott
yeah the ZF4s have the loops on the front and back making it easy to slip on
https://www.strava.com/...tes/zachary_mckinney
Re: Sockless shoe recommendations? [plant_based] [ In reply to ]
I always had good luck sockless with On Cloudflow.
I have flat feet so like shoes with some stability. I used to race in Saucony Fasttwitch, but have switched to Asics Noosa Tri because my old legs like a little more padding.
salmon - not because I'm a fish
Asics Tri Noosa 14 has a fantastic sock like liner, that doesn't require socks
Regards, Richard
3D Bits and Pieces - https://www.printables.com/@thetrickster_793480
Re: Sockless shoe recommendations? [thetrickster] [ In reply to ]
The ASICS looks solid too. Will check them out if the Skechers don’t work out. Thank you!
I have run sockless with no problems in every shoe that I have ever tried. I wouldn't worry about it.
Re: Sockless shoe recommendations? [tomljones3] [ In reply to ]
Unfortunately I’ve tried that and some of my favorites have funky seams that I don’t notice with socks but rub without them.
Use to run in Zoots, and although they were designed as sockless they still rubbed and chafed a lot of people. Now running in Nike Vaporflys (which you indicated you didn’t like), but the point is that most shoes will have some rub points. I’ll test out a shoe sockless for a one or two mile run and determine the rub points. Then I lube the area (body glide) and test them again. Try it on a current pair of your favorite shoes and see if this alleviates the friction areas.
x2
Member of the Litespeed Factory Team
www.litespeed.com
