B_Doughtie wrote:
Problem with that venue is regardless of which side of the park you race in (spring race does one side and fall race is on other side with a different race organizer and neither close the road), there is only 1 main road that you must use to get back into the parks. Which that road is sketchy and super busy and even with “police support” it’s still fully open roads. Of course this is small “local” races with at most what 300 people, so the capacity to do more just isn’t there. It’s an unfortunate issue because that area can take advantage of good terrain (hills) to make for good courses.
But that lake area likely has no where that’s “good” without riding on a major road(s). I guess they could look into Baptist Rd section but then you’d be crossing highway 98 which would be another big issue.
Triangle tri in June will have the busiest road closed to traffic (No Du option but there is a super sprint option).
For the du or the oly make Baptist 2x out and back with a jaunt down to uturn on Santee Rd. Then no leaving the safer area. I often go ride TT bike that Baptist Rd. The local tri series operates out of the Baptist Rd park location.
