Installing new cassette: what tools do I need?
I've bought a new rear wheel for my 2009 Cervelo P2 (10 speed Shimano) and want to learn how to install the 10-speed cassette. Looking online, it seems I need a chain-whip and a crescent wrench. I've found the chain whip that is for Shimano 7-11 speed, but I want to know if there's a special type of crescent wrench I will need that is specific to Cervelo, or if a generic crescent wrench will work. The rear wheel is pretty expensive, so I don't want to mess it up, but I also feel like this is something I should be able to do myself. Thanks for help.
Re: Installing new cassette: what tools do I need? [samtridad] [ In reply to ]
Search cassette removal tool
http://www.TriScottsdale.org
You need a chain whip and a cassette lockring tool. Some lockring tools require a crescent wrench (or similar) to turn them, some not.
And don't forget the spacers (1 x 1.8mm, 1 x 1mm) before sliding on the 10sp cassette - the new wheel will have an 11sp freehub.
A hammer
"Isn't RandMart the old punk rock dude who had the crazy ex? Then this post checks out"
I've learned from my mistakes, and I'm sure I could repeat them --- exactly
Re: Installing new cassette: what tools do I need? [Ajax Bay] [ In reply to ]
This is the wheel: https://flocycling.com/...disc-aluminum-carbon and it says freehub is "Shimano/SRAM 10/11". So the default is the 11sp and you have to add a spacer if you have 10sp?
You need to put a 2.85mm spacer behind the cassette, or one 1.85mm spacer and one 1mm spacer.
Re: Installing new cassette: what tools do I need? [jimatbeyond] [ In reply to ]
Do you usually get the spacers with the wheel? Or with the cassette? Or is it something you buy separately?
Typically, the wheel manufacturer will include a 1.85mm spacer and Shimano will provide a 1mm spacer with the cassette.
If you bought the wheel new, correct spacer should have been in the box.
Re: Installing new cassette: what tools do I need? [fredly] [ In reply to ]
Thanks for the help.
Thanks for your help Jim.
