desert dude wrote:
are you getting > 92-93% hr response?
how much total time out of your 25min at intensity do you think you're actually getting at >92%?
that should be enough info for you (or anyone) to evaluate if their vo2max intervals are really vo2max intervals or just really hard intervals and/or they need to change their really hard intervals to actual vo2max intervals (
After reading this thread and attempting to evaluate my own Vo2 intervals (when i do them), I think they are just really hard intervals... they are certainly Vo2 power at around the 115-120%, but my HR might only just touch the 92% mark for a few seconds towards the end of a rep, and not even get that high for the first few. Based on a 3 minute 1:1 interval. I'll hold my 90ish cadence throughout.
But im not really sure how im going to adjust them going forward... getting my HR to pop up on the bike has never been easy for me, with running it will pop up to the roughly expected HR zones for the pace, but with cycling I feel like the muscles fail before being able to push the heart and lungs... for example stretching out those 3 minute intervals to 4-5 would be really really tough, and id fail later intervals almost certainly. If i dropped the power so i could stretch them out that bit longer, then I dont think the HR would get to where I need it either. I think ill need to either have harder starts to the interval in an attempt to spike the HR before then lowering to a more sustainable level and holding on... or lower the power slightly to say 108% and try to go even longer to maybe 7-10 minutes.
I had a quick look over my strava last year and only 1 session did i ever hold 92%+ hr for more than a few seconds (despite many sessions feeling like i was going to fall off the bike) .. and that was on a really steep and long local climb, about 1 hour 20 into my ride, where it was a case of push the pedals or stop.. i averaged 122% for 12ish minutes, with my HR hitting 92% just over 3 minutes in... but my cadence was 71 which is way below where i usually ride and it felt more like a weights session than cycling, so i assume i was tapping into the muscular system far more than ideally to train vo2. That was a max effort tho and i had to tap out at that point half way up the hill.
@the.lazy.triathlete https://www.strava.com/athletes/18691068
