dunno wrote:
I'm going around in circles and can't decide between an aerohead or codatronca. Please please please can someone talk me into one or the other? Concerns with the aerohead is everyone seems to complain how heavy it is. But also regularly is mentioned as being the fastest.
There is little info on the Codatronca but seems it might be the better option?
Codatronca has an issue, which is that the visor drops on the nose when riding. I manage to over come this to unclip the back part of the structural part on the back side and screw it literally with a screw further forward in the helmet. So that the helmet sits further back on your head. I also used the dremel on the visor to cut out the nose gap a bit higher.
We do have a sample visor from MET direclty that would help the ‘ nose touching’ issue but as far as i know it went not in production.
For the rest it was my helmet to go………until i got the Rudy Project The Wing.
That is for the winner of all times. It is light, almost like road helmer, the fron of the visor is cut higher so you don’t look at the edge of the helmet (that sounds small but in practice it an excellent feature), you get it on really east\y because you can make slightly wider then you need in fit and when on you can adjust the fit with 2 fingers on the fly, it is super cool (for an aero helmet) due to the fact that the vent on the front sits exactly in the right spot. And actually not that small as a lot of people mentioned. I fit an S/M but sold L to a guy with head size 63 cm
Jeroen
