Xavier wrote:
KEnglish wrote:
https://www.aero-coach.co.uk/aerodynamics-of-racing-tyres
The TT has the same structure/casing as the normal pro one, so would assume same aero profile.
Also parcours has similar results, but large grain of salt as the deltas (particularly at 0 yaw) between tires just donāt seem plausible. Could because their two tests were conducted a year apart:
https://www.parcours.cc/...g-the-new-generation Schwalbe Pro One TT is very aero. So much so in fact that in very windy conditions, on our Zephyr front wheel (78mm) a 25mm Pro One TT is as fast as a Corsa Speed (23mm or 25mm). As the Schwalbe TT is more puncture resistant than a Corsa Speed it is a great backup combination for windy days or terrible road surfaces. On our Titan (which is deeper at 100mm, and isn't as wide externally as the Zephyr) the Schwalbe TT isn't as good and the Corsa Speed beats it (in both 23mm and 25mm). It does depend a lot on what wheel you're putting it on.
These are our recommendations for tyre choice for racing/training based on aero and Crr data, in order of real world speed:
1. Veloflex Record - fastest thing you can ride, not for very broken surfaces. Similar aerodynamics to the Corsa Speed but the Crr is so much lower than everything no other tyre is faster even if that other tyre is more aero
2. Corsa Speed - great option as you can run it tubeless or clincher, again not for very broken surfaces. This was our top recommendation on the fastest option before the new Veloflex Record came out but is the fastest tubeless tyre
3. Schwalbe Pro One TT - tubeless or clincher, much better for puncture protection than the Corsa Speed, very nearly as fast. If you want to race on a fast tyre in any conditions this is a good option
4. Continental GP5000 - tubeless or clincher. This for everything else. You can race and train on GP5000s and if you want a set of wheels you use at all times on your bike this is what to go with
Of course there are others in there like the Michelin, Pirelli, Specialized, but that's our simplified recommendation list. As stock on our wheels we supply Veloflex, Vittoria, Continental and can supply Schwalbe if people want them but we thought it would be better to make it even easier to understand (Veloflex for best, Vittoria for best tubeless, GP5000 for everything else).
Hey Xavier- dredging up this older post, trying to decide wheel/tire combo for my first race this season. If Iām doing an event (70.3) with a lot of broken/cracked roads, would you think the Schwalbe on the Titan is a better choice? Or Titan is just CS or bust? If I rode an alternate wheel itād have to be clincher, so thoughts on Schwalbe w/ tube vs CS without?
Dimond Bikes Superfan
