Tom A. wrote:
Jo O. wrote:
Campagnolo hydro shifters use the same oil. Expensive experiment though.
Yeah...and their braking systems are actually designed by Magura. That said, from the pics I've seen, they appear to use the high pressure hose and fittings, not the lower pressure hose :-(
Another option (and also expensive) is Rotor, where the brakes are also designed/made by Magura. From what I can tell, the RT6/8 style hydraulic rim brakes use the same master cylinder bore diameter as the HS11/22/33 rim brakes, so the Rotor rim levers should work just fine.
I have tried their hydro shifters:
As much as I would like their engineering they just do not shift very well.
more of a hydro friction that indexed shifting.
