tririg tilt hardware
has anybody tried to use it to replace the riser/stack hardware on a felt IA?
Re: tririg tilt hardware [jwrdds] [ In reply to ]
Bump...I'm also curious about this
I believe the bolt holes are 15mm apart for Felt.
Why not use washers instead?
Eric Reid
AeroFit | Instagram Portfolio Coaching and Bike Fitting
Chapel Hill, NC
Aerodynamic Optimized Bike Fitting, Retul Pre-Purchase Bike Fitting, USAT Level 1 Triathlon Coaching, Nutrition
Ask me: Scody Optimized Speed Suits | CeramicSpeed Oversized Pulley Systems | HUUB Skinsuits and Wetsuits | Bombshell Aerodynamic BMX Wheels
Re: tririg tilt hardware [ericMPro] [ In reply to ]
where do you put the washers? and do you use the same screw lengths or one longer than the other?
Eric is right...bolt holes don’t line up. I emailed nick about this a while back and he said it wouldn’t work. He has been very upfront about what tr products will and work for my ia I the past and when he said it wouldn’t mix I took him at his word. I can’t believe felt hasn’t created any tilt options as an add on for the ia.
Re: tririg tilt hardware [anthonypat] [ In reply to ]
anthonypat wrote:
Eric is ringer...bolt holes don’t line up. I emailed nick about this a while back and he said it wouldn’t work. He has been very upfront about what tr products will and work for my ia I the past and when he said it wouldn’t mix I took him at his word. I can’t believe felt hasn’t created any tilt options as an add on for the ia.
Dcohen or similar sells the stuff on shapeways. Also a member of this forum.
