Replacing cassette - question to the ST crowd
Hi ST Crowd
Just after some basic advice. I'm about the replace a 25-11 (10spd) cassette with a 28-11 (10spd) instead.
Question - would I or do I need to do any re-indexing of the gears/rear derailleur when replacing the cassette.
Thats all - Thanks in advance
Re: Replacing cassette - question to the ST crowd [sambadhillon] [ In reply to ]
There's a very small chance you could need to replace the chain... But, since you are only adding 3 teeth, probably not. Your chain would have to be pretty tight at 25 to not be able to support a 28.
Otherwise, just put it on and go. It's usually a good idea to run through the gears to make sure you don't need to make a slight adjustment to either H/L limit screws or derailleur barrel adjuster. Most likely it just works, though.
Cassette ratios are generally referred to with the smallest cog first (i.e.- 11-25 or 11-28).
Re: Replacing cassette - question to the ST crowd [Tom_hampton] [ In reply to ]
Thanks for the reply Tom_h
Good call on the chain - never thought about that.
Will require some experimenting on the weekend.
Just trying to be more self reliant these days rather than going to the LBS for all aspects of bike maintenance.
Re: Replacing cassette - question to the ST crowd [jimatbeyond] [ In reply to ]
Duly noted jim
In addition to what Tom said, you'll likely need to adjust your B screw. Screwing it "in" rotates the derailleur allowing you to set the clearance of the upper jockey wheel and the largest cog on the cassette.
Re: Replacing cassette - question to the ST crowd [FatandSlow] [ In reply to ]
This will probably be the only thing you will have to do.
sambadhillon wrote:
Hi ST Crowd
Likely 1 extra link on the chain and a few mm extra space between the cassette and pulley wheel. Once it is set for a 28 then it can easily be swapped back to 25 with zero issues. This is for absolutely optimal shifting, in reality you will probably be fine. On occasion going from sram to shimano will have different spacing and the limits might need slight adjustment.
http://riseabovecyclingpodcast.podbean.com/
