UCI rules state:
The main part of the extension is 4.5cm. Does anyone know if they're cracking down on this?
Elbow rests must be made up of two parts (one part for each arm) and are only allowed if extensions are added ; -
The maximum width of each elbow rest is 12.5cm ; -
The maximum length of each elbow rest is 12.5cm ; -
The maximum inclination of each elbow rest (measured on the support surface of the arm) is 15 degrees ; -
The maximum dimension of the cross section of each extension is 4cm ; -
The height difference between the elbow support point (midpoint of the elbow rest) and the highest or lowest point of the extension (including accessory) must be less than 10cm.
