Re: Magura RT6 brake lever leaking [Sphutchings] [ In reply to ]
Add another one to the Magura brakes are leaking crew. My front brake lever was really tight, then all of the sudden there was a huge "give" and fluid started leaking everywhere.
I'm afraid to even ride these things again. Are there alternatives for tri-bikes with rim brakes?
Re: Magura RT6 brake lever leaking [reefblastbody] [ In reply to ]
Add one more to the leaking RT8 TT crew.. Mine is the front lever of a 2016 P5
Tempted to do the seal swap because the lever isn't functioning right now anyhow, and what's to lose other than more fluid ?
Quick update here. I replaced the Magura system with Omega One (https://tririg.com/...riant=41063608680617)
The bike tech I use (this work is above my skill level) didn't have any problems with the install.
Only issue was that the Omega One set *does not* come with levers. So you'll need to pick up a set of levers as well.
