A527G wrote:
lyrrad wrote:
This is a downright dangerous repair.
The O-ring is quite capable of letting go quite abruptly under pressure and leaving you with no brakes.
The original seal is made so that increasing pressure will make it seal better and will not catastrophically fail.
Go to a seal shop and get the right sort of seal and do not encourage anybody else to do this modification as you do not understand what you are doing.
You probably should have quoted the original poster who 'invented' this repair.....but anyways, your genuine concern is appreciated. We (the "Magura-brakes-for-life" people) understand the lever was not made as a serviceable part and this is not a repair endorsed in any way by Magura. We accept the risk of working on our own brakes but suggesting that the replacement o-ring will just spontaneously and catastrophically fail seems a bit histrionic. I'll admit, I'm not an engineer in any capacity but I must have missed your area of expertise? (Seems that some other posters are also wondering how you can so confidently predict that this o-ring will just "let go"). You've disassembled the Magura lever and examined the OE o-ring vs. the replacement ? Or you're an o-ring engineer that can tell just by looking at a picture? Don't worry, I'm on my way now to my neighborhood seal shop to get this taken care of.
If you look at the shape of the seal, it's in the form of a "cup", so that as the plunger is depressed, the fluid pressure will tend to push the outer lip of the cup harder against the bore of the cylinder.
As far as failure goes, I think lyrrad may be referring to the fact that increasing pressure could "push" fluid past the O-ring seal surface easier than the original seal design. On that point, I don't know enough about these sorts of details of hydraulic system designs to offer an opinion. I do know that the increasing pressure on the o-ring will tend to push it against the bore at the outer, rearward corner of the "gland" (the circumferential groove the seal is located in) which will also decrease the likelihood of leakage past the seal, as long as there is sufficient compression on the outer diameter of the O-ring when installed. I suspect the cup type of seal was also done as a way to decrease the seal drag when released so that lever return is faster/easier...but, like I said, most of what I just wrote is informed speculation based on other O-ring seal design experience. I would guess that using an O-ring in this location (of proper radial compression) might make the lever travel a bit slow, in both directions, even if it ends up operating OK.
Of course, if you can source the same type of seal used by the factory, that will be the best, most prudent, choice, obviously...
Side note: Based on the above description of the O-ring, I take it the piston bore diameter is ~12mm? Does anyone know, or can you figure out the total travel of the piston? I'm always trying to figure out if various master cylinders can be used with the Magura rim brakes (both these RT style, and the HS ones as well). I guess I could just disassemble one of the RT levers I have in the garage if nobody knows ;-)
