Re: Tires [rruff]
Re: Tires [GoJohnnyGo]
GoJohnnyGo wrote:
BryanD wrote:
S-Works Turbo and GP4000 are pretty much identicalSo what should I get.... I need new tires and trying to buy some speed... LBS has conti up 4000s, bkntrager r4s and Victoria corsa
Keep in mind that the S-Works Turbo tested by BRR was a 24c width. If you wanted a narrower tire up front, Tom A's testing showed that the 22c had quite a bit higher Crr than the 24c.
Re: Tires [uva0224]
uva0224 wrote:
Thanks! Why not just attack and force?
Is GPTT that much better than force?
Yes. Much lighter anyway as the Force is ~220g. Use the Force for training if you have to buy Attack/Force set.
GP4000s installed and ready for tomorrow am test ride.
