Re: Cranksets....need your advice... [fredly] [ In reply to ]
I also thought the use of the outer bearing style was to eliminate weight and parts [no insert, no shaft etc] at the expense of life cycle....i still can't figure out why the BB has to be so complicated to begin with....
I do have one question in regards to the integrated headset design.....i can't figure out for the life of me why there is no sleeve in between the upper and lower bearings to allow support and compresion limits...this is the only design that i have come accross like it, every bearing on a car is supported and limited and last a long time...just how long will those headsets last???
Re: Cranksets....need your advice... [6cuda6] [ In reply to ]
I still dont know what was fixed...larger spindly...were the old ones breaking (I never seen a spindle break). I never seen one flex, never heard anyone claim theirs did either for that matter. Never heard of people complaining that their (quality) BB's were wearing out any faster than 10-15 years...oh..and dont forget that the Record Carbon Crank with the Record BB is LIGHTER than the new DuraAce...where again is the benifit? I am missing something I am sure.
""frame flex in the BB" is essentially non-existant, if by BB we are referring to the BB shell. If by BB we are referring to an undefined bottom-ish area of the bike, than it does in fact occur, may well be the source of inefficiencies, and it's consideration is of absolutely no value in a discussion of the relative efficiencies of different crank/bb configurations."
Wow, you completely missed the point, didn't you. Maybe we are just having different discussions. To enlighten you, the discussion at hand is not about the relative efficiencies of different crank/bb configurations in a lab environment or on paper. Rather, we are discussing whether or not a "stiffer" BB/Crank configuration has any benefit if there is still lateral movement in the "undefined bottomish-area of the bike" (commonly referred to in cycling circles as the BB area or, when referring to frames, simply the "BB")when pedaling under load.
Feel free to chime in with something relevant.
Re: Cranksets....need your advice... [JohnA] [ In reply to ]
So I guess we have decided that there is no actual improvement in performance, and probably a higher rate of failure with the external bearing systems....neat...
I have ridden Shimano DA10...and ride Record on my bikes...blind fold me and I cant tell you one crank from the other when I am riding...maybe I am dumb.
Thanks for "enlightening me..."
Are you attempting to ask/say:
-the issue of crank/bb stiffness is irrelevant because the benefits of increased stiffness in this area are lost in frame flex inefficiencies/noise?
or,
"who cares about a stiffer crank, you don't lose energy there, because the frame is flexing already!"
If this is what you are trying to say,
- frame flex does not really work that way in regards to the drivetrain.
My distinction between BB and "commonly referred to as BB" is actually meaningful in a real discussion of the issues you attempt to raise. The *only* source of flex in the actual BB area is the spindle/crank. This interface is subject to quantifiably different forces than the area you seem to be referring to in your over-generalization. To simplify: flexion of the spider, crank arms in 3 axes relative to the BB centerline, and chainring flexion are all factors in this phase of energy transfer, and are not, or manifest differently in a discussion of frame flex.
- You *are* losing energy there, so yeah, it does matter.
Well, maybe it doesn't matter for you, but it does for many riders. ST BBs are flexy, measureably so, and not in a way that is completely lost in the noise of frame flex, which doesn't affect power transmission in a bicycle in the same way that BB flex does. Why ride something you know to be less efficient, even if microscopically so?
I stopped using Campy cranksets when I actually saw a set of stiffness tests for the Record crank/BB (and no, I don't have them sitting around anymore, sorry, wish I did.) They are markedly less stiff than any of the competition, almost all the difference comes from the BB, and the results were more than enough to convince me.
PS - I still have a set of Record AL cranks, 172.5, sitting in the closet; sold the other two sets. I will make somebody a good deal on them... but will also tell them up-front that a set of the cheap FSA AL cranks, with an ISIS bb will outperform them on any given bike (as long as the crappy bearing set holds out, anyways..)
Are there any studies that show the extra stiffness in the BB will have a SIGNIFICANT effect on performance? Exactly how much energy is lost?
There are a lot of things on the bike that could be microscopically improved that will have virtually no effect on real world performance. Just because you get an almost immeasureable benefit does not necessarily make something superior if it costs more, requires higher maintenance or is imcompatible with other parts.
Fredly [ In reply to ]
You are a real beauty, and I do mean that in a nice way. You argue in a logical engineering thoughtfulness on how internal bearings work better and some cranks are stiffer and it is now the industrial norm. Then state how you have switched based on an article that plainly shows that one crank bearing/BB system is what 5% stiffer? While you ignore the fact that the bicycle is an engineering dinosaur.
Look at the way we shift gears, we use a stick to drag or push a moving chain to another gear and then ride with a chain that is not even on straight. Yea that is an engineering marvel at its finest. And you worry about crank stiffness?
With that kind of engineering I will take my old Campy cranks with Phil Wood BB set ups for the next thirty years or so on my Matt Chester, Merlin, Moots, and Dean Ti bikes which I plan to still be riding on at that time when I turn 84. And with Phil some of the same BB will probably be with me. Call me "old skool" but I don't think even a 100% increase in crank stiffness would knock 3 seconds off my 40k TT split. But following Shimanos changes in bearing and BB standards sure will knock a few hundred bucks out of my wallet.
When I race TT my chainline is perfect (I race fixed) Every time you race, think about all the watts you lose in mechinical drag on your rig with that chain on crooked. And how those stiffer cranks are actually increasing drag as they aren't flexing with the load as much as that guy with the old sskool BB .Cheers G
Re: Fredly [G-man] [ In reply to ]
I think that what I need to do is get steel studs mounted to the bones in my feet...these studs will attach directly to my cleats that will snap directly to the studs, and thus directly to the bones in my feet (much like artificial teeth). This will in turn give me the best possible connection to my pedals and the bicycle with out the robbing of energy caused by the sole of my foot compressing, and my shoes flexing.
My gawd am I going to be fast....time to take out all the weak links folks....
"you ignore the fact that the bicycle is an engineering dinosaur"
Whatever.
The modern geared bicycle is one of the most efficient means of transportation ever created, THE most efficent mechanism for human powered locomotion yet devised, and, in fact, not at all what you are claiming.
And, btw, the increase in efficiency of a fixed gear bicycle over a geared one is statistically insignificant (you might want to look up the research.)
"increasing drag as they aren't flexing with the load as much as that guy with the old sskool BB"
Huh? Nonsense. Pure flatulence.
Re: Fredly [fredly] [ In reply to ]
I have seen more than one time (Myth Busters too I think) that the chain and cog are one of the best ways to transform energy.
Re: Fredly [Record10Carbon] [ In reply to ]
Yup. No question about it. Nobody has been able to top chain drive for low power applications, especially when weight is a factor - and many, many people have tried.
I'm still waiting to see some hard evidence that increased BB stiffness will lead to better performance. In fact many bicycle components, including the frame are not designed strictly for stiffness. Isn't it possible that a less stiff BB might actually reduce fatigue due to road shock?
Show me a modern marvel besides the bike that they intentionally design the chain to drive in another direction besides straight. That is why we wear out chains so quickly. My dirt bike chain moves at what 10 times the speed of my bike chain and lasts mult. years. Ask any design engineer, they will laugh at the inefficiencies of the deraileur bicycle drive line, but have yet to come up to a better alternative. I agree that the bike is a timeless invention, but to worry enough about BB flex to change systems is a waste of money..
I am no scientist, but I know that you lose more watts of power to chainline friction than BB flex. Maybe you can show me a study that mentions different, but I would think there isn't one out there.
Re: Fredly [Wolfwood] [ In reply to ]
"Isn't it possible that a less stiff BB might actually reduce fatigue due to road shock?"
It's been tried, and it's a bad idea.
G-man,
1) I am not arguing that anyone should change crank systems.
2) Design engineers do not laugh at the inefficiencies of bicycle chain drive lines. (I stand next to one 40 hours a week.) I repeat; the modern geared bicycle is the single most efficient means of transferring human energy into locomotion ever devised. The main reason for this is the incredible efficiency of chain drive systems, and one of the great things about chain drive is it's ability to remain incredibly efficient when linking non-aligned cogs (as compared to, eg, a belt drive.)
3) The main reason for the longevity of your dirt bike chain is mass, and yes, the fact that it is held in alignment, and the fact that it is not derailed. Chain wear can not, in and of itself, be used as a basis from which to draw any meaningful conclusions regarding drivetrain efficiency.
3) you aren't a scientist.
Exactly what was tried? What was compared? The components have to be of similar spec otherwise the conclusions you draw could be completely wrong.
For example you could compare a suspension fork to a rigid fork for a road bike and conclude that more stiffness in the fork is always better. However you would be wrong. It is possible to design a fork that is too stiff and absorbs little road shock.
Another tip in the line of it being faster to "ride the Paint" in a TT or Tri is to ride in gear combos that give you the best chainline. If you don't believe that one, put a track bike in the stand and give the crank a spin. Then set your chainline off one cog and watch how much less it spins. Then if you can even keep the chain on try two cogs off and watch it. I do realize that the derailleur reduces wattage lost, but a sideways chainline will eat up some watts and a serious cross chain will eat up more than a 1 cog chainline problem.
Really good points.
I completely agree that the BB is overcomplicated; I think this is because designers are trying to stuff 15 pounds of performance in a 10 pound bag - an increase in BB shell ID would allow for significantly less complicated designs....
The support/thrust sleeve is left out because it would be heavy, or perceived to be so - and bearing life is *pretty* good without it - and ACBs do help to alleviate the necessity to limit compression in this type of application - although a bunch of bike designers are using the ACB to self-center the bearings, and relax the machining tolerance on the ID of the bearing seat, which I think is a pretty bad design...
Quote:
To be completely blunt, designing suspension into the drivetrain is asinine. Forks are an entirely different subject, and your example is ridculous.
Quote:
You can't use track chainline inefficiencies as an archetype to discuss inefficiency in geared bicycles. The cog profiles, chain tension, and chain flexibility (if you are using track pitch) are all different enough to completely invalidate the comparison. Apples and oranges.
I'm not making any argument. I'm being objective about it. I'm open to the possibility. I don't know if there is any benefit or not to having a stiffer BB.
I'd like to see some scientific proof as to how much gain I can expect from having a stiffer BB. Could a less stiff BB with better bearings outperform a stiffer BB with poorer bearings? Maybe the stiffer design allows more dirt to enter the system eventually degrading the performance and durability?
