Thanks for "enlightening me..."
Are you attempting to ask/say:
-the issue of crank/bb stiffness is irrelevant because the benefits of increased stiffness in this area are lost in frame flex inefficiencies/noise?
or,
"who cares about a stiffer crank, you don't lose energy there, because the frame is flexing already!"
If this is what you are trying to say,
- frame flex does not really work that way in regards to the drivetrain.
My distinction between BB and "commonly referred to as BB" is actually meaningful in a real discussion of the issues you attempt to raise. The *only* source of flex in the actual BB area is the spindle/crank. This interface is subject to quantifiably different forces than the area you seem to be referring to in your over-generalization. To simplify: flexion of the spider, crank arms in 3 axes relative to the BB centerline, and chainring flexion are all factors in this phase of energy transfer, and are not, or manifest differently in a discussion of frame flex.
- You *are* losing energy there, so yeah, it does matter.
Well, maybe it doesn't matter for you, but it does for many riders. ST BBs are flexy, measureably so, and not in a way that is completely lost in the noise of frame flex, which doesn't affect power transmission in a bicycle in the same way that BB flex does. Why ride something you know to be less efficient, even if microscopically so?
I stopped using Campy cranksets when I actually saw a set of stiffness tests for the Record crank/BB (and no, I don't have them sitting around anymore, sorry, wish I did.) They are markedly less stiff than any of the competition, almost all the difference comes from the BB, and the results were more than enough to convince me.
PS - I still have a set of Record AL cranks, 172.5, sitting in the closet; sold the other two sets. I will make somebody a good deal on them... but will also tell them up-front that a set of the cheap FSA AL cranks, with an ISIS bb will outperform them on any given bike (as long as the crappy bearing set holds out, anyways..)
Coaching and bike fit -
http://source-e.net/ Cyclocross blog -
https://crosssports.net/ BJJ instruction -
https://ballardbjj.com/
