With Cervelo revealing the shiny new P5, I it would be good to start a discussion on the aerodynamics of the new P5, and how it compares to other bikes currently out there.
I've always loved TT/Tri Bikes, and being in the world of engineering I tend to over analyze everything, including my hobbies :) Feel free to add on anything you notice that stands out to you about the design of the P5, or any other aero designs in the modern TT/Tri bike competition!
A little background on myself: BS in Aerospace engineering, and 3 years professional experience as an aerodynamics engineer, conducting CFD (Computational Fluid Dynamics). The CFD that I conduct utilizes some of the same software they used to design the P5, so I am very familiar with the program and it's capabilities, and it has proven thorugh my work (and many others) to be a very robust and accurate CFD code. That being said my work is in the field of aircraft/spacecraft, so the airspeed is a little higher in my work.
The P5 is a stunning bike, and from and aero point of view, it is extremely clean. Here are some of the things I noticed:
Also keep in mind that while all these aerodynamic improvements to bikes over the past few years that can buy you precious seconds, ~70% of the drag associated in the TT/Tri world is attributed to the rider. So while having a machine like the P5 or the SC can make you faster, be sure to get fitted for your optimal aero position and accessories (helmet, speed suit, shoe covers, etc.) dialed in to make the most of the complete set-up!
David
2007 Trek Madone 5.2 Discovery Channel
2011 Trek Speed Concept 9.5
- The front brake setup is very clean and aerodynamic (similar aero to Trek SC), however the fork sits closer to the rim than the SC which can lead to "hot spots" of stagnation between the rim and the fork (boundary layer interaction). Trek widened the fork to the SC to minimize the flow interaction between the fork and the rotating wheel. Both bikes have a very clean front end, which is essential to maintaining smooth airflow over the cross section of the bike/rider.
- The basebar/aerobar setup is unique, especially the high V setup. It looks to be highly adjustable, also along the same lines as the SC.
- Frame design is the place where the design teams from Trek and Cervelo differ the most. The Trek SC was designed to be fast across a large array of wind angles (look up the Trek White paper on the Kamm Tail design), which reduce drag in side-slip due to the ability of the airfoil cross-section to keep airflow attached (reducing drag) over a large array of wind angles. Cervelo has always stuck with a sharp trailing edge design, which looks slick and performs great at low wind angles, however a sharp trailing edge leads to flow separation at lower side-slip angles than the Kamm tail design. The P5 also has a very high surface area from the side so riders will most likely have a harder time with handling in cross-winds. So who wins in this regard? In my opinion (and experience when comparing CFD-Wind Tunnel-Flight Data) airflow is rarely clean and at an ideal angle, so designing an airfoil shape that is more forgiving to various wind conditions will be a faster "real world" design.
- I was glad to see Cervelo adopt more integration and storage options on the P5, the hydration is still good (similar to P4) but now with an integrated Di2 battery and "Bento Box" setup (also similar to SC Speed Box). This is a huge benefit for triathletes who would get extremely fast/aerodynamic bikes and bolt 4 bottles and saddle bags!
David
