In Reply To:
Did you notice a change in your running splits, pace, or PE after these lower cadence efforts (if you're a triathlete/duathlete). I'd like to start focusing my cadence at 85rpm in an effort to go faster, but I don't want to sacrifice my runs splits.
It's hard for me to separate out post-cadence-change running results. My running has been on a positive track for 2 years now, so I would be setting run leg PR's anyway.
With that disclaimer, I will say that I am running better than ever off the bike. At the very least, I would say the lower cadences are not holding me back. My triathlon/duathlon run paces are consistent with my open run paces.
One reason I suggest that people tape over their cadence display and focus on watts and PE is that we want to find the best combination of power and fatigue resistance. I have the sense that the cadence that brings my PE at a given wattage to a minimum is the cadence that leaves my legs most fresh for the run.
If you want to make a change, make the change and give it six weeks. Six weeks is enough time to know if something is going to work (our bodies adapt remarkably quickly). Run careful tests before and after and try to decide which cadence is best.
