In Reply To:
In your opinion, which works best for a relatively weaker rider, lower or higher cadence? (weaker as in ability to generate force ex. weight lifting but not aerobically)
No easy answers like this -- you've got to go out and find out. Trial and error.
That being said, controlled lab tests have generally showed that lesser power outputs beg for lower cadences. This is in part why mortals like us should not try to emulate Lance. When Lance is attacking up a Alp at 105 rpms, he's cranking out 450 watts. When I'm "attacking" the overweight ladies in the TNT group at my super-human 230 watts, I find that a cadence around 75-80 does the trick. More than that and my power begins to fade; less than that and my power also begins to fade.
BTW -- ability (or inability) to generate force is not the limiter faced by a rider with modest ability. Any of us can generate the forces required. It's the
inability to maintain those forces repeatedly that is our limiter. The limiter is one of fuel processing, or oxygen. The limiter in triathlon cycling is always aerobic power production, not force.
It is tempting for me to think, "Well, I'm not very strong. I can barely squat half my weight. Therefore, I will pedal faster than the other guy to make up for my lack of strength." Wrong approach. Even the very weak (from a strength standpoint) can generate plenty of force on the bike. Again, the limiter is feeding the force-generating process rapidly enough to maintain it. That is a purely aerobic limiter. It is trained the old fashioned way -- lots of bike riding.
Even "weak" riders might benefit from low-ish cadences (70s-80s). The only way to know for sure is to run some self-experiments.
If I were forced to make a guess, I would guess that a typical MOP age grouper in a long-course race should not be pedaling at more than about 80-82. Exceptions will surely exist, but I think this is right for most people, and would be a good place to start for someone without access to a power meter.
