In Reply To:
So why you would say "energy efficiency is not the limiting factor in these races" is seemingly nonsensical to me.
Frank
Because -- If I'm rolling along at a super-human 27% efficiency, why is it that Luke Bell will go roaring past me at a mortal 23% efficiency? Because he's cranking out 300+ watts against my piddling 225, that's why.
But -- that's not the interesting analysis. What if instead we can induce Luke to put out his 300 watts at 24% instead? He's now burning a little less fuel, correct? So what? His race split is still the same. But -- there is more of course.
Now lets say that Luke can up the wattage to 310
at the same fuel burn rate (and O2 uptake rate). Aha! Is this the holy grail we seek? After all, isn't that the crux of the efficiency argument? The
sine qua non? Yes it is,
but it is not the holy grail of performance.
There are physiological costs to adding wattage. Waste products, muscle fatigue, central fatigue. All sorts of things conspire to drag the athlete off to the side of the road. Remember -- efficiency has to do with
fuel usage. We can all acknowledge that plenty of athletes flame out in an IM long before they run out of fuel. If Simon Lessing had ridden more
efficiently in Kona last month, he would have been sitting on the side of the road with more glycogen stores. But, he would
still have been sitting on the side of the road!
The potential for increased efficiency in powering a fixed-motion device comes from (a) lots of training of the existing muscle set; or (b) adding net new muscles to the work.
If PCs add muscles (which, on a
net basis, I doubt) to the work output, then any increase in power
comes at a cost. I again return to my earlier assertion -- where is the increase in power over a given work duration? Where is the 4-hour IM ride? Where is the 44-minute 40k? The 2:35 IM run split? Anybody? Lab results? Increases in O2 uptake at a given power level. Sorry -- not conclusive.
One of the hallmarks of a cultish following of a given belief system is this: When a given adherent fails to achieve the results as advertised, the leader of the belief system falls back to the argument, "You didn't do it right, and your failure to achieve results serves only to reinforce the greatness of this system. Since you did it wrong and didn't get results, then you have proven that if one does it right, one will get results."
But a meeting of two enthusiastic believers results in
asinus asinum fricat. That's enough Latin for one night. I'll let somebody else look that one up. And, Frank, I do not intend to engage in
argumentum ad hominem. You are a gentleman and I mean no offense.
