Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [velorunner] [ In reply to ]
velorunner wrote:
It looked like Marquart had a stacked double bottle BTA setup in Singapore, but I'm not sure how.
https://www.instagram.com/p/C6RXJU8t7qa/
He's got both bottles angled down, though. Mine would leak all over everything.
He was afraid to be thirsty
2 bottles between the arms
A bottle holder on the back
A round bottle on the frame
Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [Jim@EROsports] [ In reply to ]
Depends on how you do it... these two seem like they are doing it right accodring to the eyeball windtunnel.
I think you need three things:
a) close the space between the aero bar extensions.
b) high hands
c) place the bottle so that it closes the gap between the head and the hands and so it directs air around the chest cavity, these guys are almost resting their chin on top of the bottle.
Jim@EROsports wrote:
marcag wrote:
timbasile wrote:
2 - I'm trying replicate the effects of a bottle down the jersey by putting the 2nd bottle (if I can) in a similar position, if I feel that the setup is safe
I wonder if anyone has tested this to be equivalent. I tried once and it wasn',t but it 1 person in the A2 tunnel.
Right with you in this. Everyone is completely misunderstanding the airflow of having a bottle down the front of the kit and just swinging at windmills with bta’s. Silly.
What's your CdA?
Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [G. Belson] [ In reply to ]
b) high hands
How would this be different than simple high hands, narrow pads, completely blocking the chest area ?
Neither of those would replicate the airflow of a bottle down the kit. Doesn't mean they don't help aerodynamically, but not in the same way, which was my point.
Jim Manton / ERO Sports
Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [timbasile] [ In reply to ]
Here's my setup. First race with this was St Anthony's and it held up to the brick road section and some bumpy streets. May go with carbon tubes at some point, so it's all matchy matchy.
Long M5 button-head hex bolts (~170mm for this setup) down into the threaded portions of the TR dragonfly - with an outer aluminum tube off Amazon with inner diameter of 5mm. Used a washer/bolt combo at the bottom of each one (underneath the dragonfly), to give it some extra staying power.
Single bottle for now. May mock up a platform to do a double-bottle using a metal plate, no angled spacers needed since already flat.
Critiques and recommended changes are welcome!
How do we feel about this setup Jim? Thinking with some extra long rear facing bottles I can basically fill the entire area between my crotch and bars ;)
Benjamin Deal - Professional - Instagram - TriRig - Lodi Cyclery
Deals on Wheels - Results, schedule, videos, sponsors
Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [realbdeal] [ In reply to ]
Meanwhile @ Ironman HQ
What's your CdA?
I'm just imaging all the sticky spray showering out of that nonstop while you ride!
Joe Skipper would be proud of you
love the battle scars on that rig!
also, looks like the bottom red bottle could scoot forward toward the riser and you could go another one behind it - turning the bike is optional! :)
Curious as to why this is the case. Is it because the tri/skin suit smoothens the flow around the water bottle as opposed to the water bottle outside the suit in spite of being (assuming) in the same vertical position and touching the rider's chest?
Hows your bike handling??? This is going to lead to alot of issues with people trying to do this and adding additional weight where it isn't designed for. You can argue it's designed for your body weight, but you can shift that when needed, a bottle is fixed and sloshing water inside. i can only see this going badly with water loading like this to add a small aero gain and putting peoples safety at risk.
Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [culpritbicycles] [ In reply to ]
not sure if this was a question for me or someone else, but the handling on my bike is good. With the single bottle, I hardly notice it. There is more change in the handling dynamics going to the tririg scoops, than adding the bottle.
Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [mrfreeze] [ In reply to ]
sorry was meant for Real Beal since he has 4 water bottles as bta.
1 is normal and standard up to 1 liter(profile design, etc) is ok. but 2 liters on stem/aerobar is alot.
Well I figured if each of my rear facing was one of these tall boys, then my weight distribution would be back to normal.
To be clear, I have no intention to run this setup. Was just screwing around while my baby was napping. Although if I were to be on a very flat course with very little turning, something like Cozumel, running those extra long bottles empty might be amazing at high yaw. Just a joke for now though.
The irony isn't whether BDeal runs it or not. The irony is that with Mortal replacing Gatorade and the jersey bottle ban, the actual fastest setup for most courses is something like this. Dangerous, reckless, ugly, legal.
IM banned the jersey bottle to keep an image of "cool triathletes" that never existed. They'll get triathlon bikes that are nearly unrideable.
Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [Lurker4] [ In reply to ]
As well as the bottles!
Re: TriRig BTA Riser - Is this Proprietary to TriRig bikes? [Mike Plumb] [ In reply to ]
Mike Plumb wrote:
not sure if everyone is overthinking this or not, I didn't have an issue mounting it on my gen 2 SC. Turn it upside down then you have a variety of holes to choose from to attach to the Bontrager mount, then the bottom of the wedge you have a variety of holes to choose from to attach to the stand.
Follow up question for your setup: are you using any wedges to angle the scoops beyond the 15 degree or so incline offered by the gen 2 Speed concept? I tend to grip my ski bars at the shifters so I'd want another 10 or 15 degrees.
Tririg does make an incline spacer kit but I'm not sure if it's 100% compatible with the scoops.
https://tririg.com/...riant=44047757148406
Not the one youre asking, but the angled spacers are absolutely compatible with the Scoops. The issue is that for standard scoops (not Scoops Ultimate or any other one piece extension), you're only able to tilt the arm cups themselves. So you'd be able to add 15 degrees to your armpads but then your hands would be way over your bar ends and shifters. On bikes with standard 22.2mm extensions, you just run high rise extensions to create this 'fake' tilt. On Speed Concepts, that's not possible unless you happen to have the adapter.
Thanks for the clarification on the compatibility. Though unless my math is off, the 10° spacers should have me exactly what I need since my arm bars have an angle of 12° and my current setup has me gripping the shifters at about 22-25° (pinky to elbow) - I'd just be angling the scoops closer to what I'm doing already.
no not using any wedges for the cups. Bolting them right to the wings has the angle about right for me. I would like to try to get a bit more reach and angle to the bar though, both are maxed out. Saw in an earlier post about turning the cradle that the extension bolts too around opposite that you can get 1-2cm more reach and bit more angle tilt so thinking about trying that.
Mike Plumb, TriPower MultiSports
Professional Running, Cycling and Multisport Coaching, F.I.S.T. Certified
http://www.tripower.org
you may contact the guys at rockerplates.de
their spin off rockairlabs does some nice customized stuff and helped out some desperate triathletes here in Europe.
contacting them does not cost anything...
Not to derail this topic further (my original question was about the bracket, which has been ordered so thank everyone! but anyhow)...
FWFI, Lionel Sanders' latest video on wind tunnel testing, has the fastest position for Day 1 as being the double barreled BTA approach (much like Marquart here but angled flat), with the top bottle explicitly positioned to replicate the effect of bottle down the jersey. 1 bottle in that same position (high against the chest) also tested faster.
https://www.youtube.com/watch?v=eytUlq-7bHg
Obviously comes with the caveat that n=1, and this is day 1 of testing and he hasn't released the day 2 video yet.
Yes, but something interesting. It bought him 1 watt. But Jonas says it was 4 watt at 0 deg.
So to come out at 1watt, it was 4 watt at 0 deg and -5 watt at 10deg by the formula they were using.
-5w at 10deg : may want to consider that one at Kona :-)
