Iām starting to travel for my races and have decided to go after a bike case. Leaning towards a hard case because of airport handle horror stories and looking specifically at the Thule bike bag which is $1000 and reportedly heavy. Anyone have this bag or would you recommend something else? Thanks!
Re: Bike travel case [TriSi]
https://bikeboxalan.com/?v=3e8d115eb4b3
I rate the Thule Roundtrip case. They make a hard case also, but they're designed primarily for road bikes, but swallow my 61cm, so can probably take care of most trips bikes also.
The case has semi flexible panels in the side, and the legs of the built in repair stand slide into the inner sleeve, adding to the protection level. The case is really well thought out and, critically for my usage case, offers similar protection level to a hard case, but folds down to a small size. I've got a road bike and mountain bike version, plus a SciCon tri-bike soft case with internal frame, which I use for my tri-bike. The Thule feels, by far, the more secure and if I travel for a race I'll try to stuff my 61cm P3 into the Thule Roundtrip road bike case.
Re: Bike travel case [benleg]
I like the BB Alan, but it's $900 to get one to the US and the Thule is $1000. How do you think it stacks up to the Thule?
I have the old version looking to upgrade to the āaeroā versionā¦. So that not need to dissemble my front end every time I fly.
Otherwise that thing is bomb prof
Not sure about Thule, look like the wheels are lose in the box and you need to dissemble front end
If you want to avoid disassembling the front: BBAlan Easyfit or Premier Bike
If you'd prefer disassembly and having a smaller case as a result: VeloVault
TriSi wrote:
Iām starting to travel for my races and have decided to go after a bike case. Leaning towards a hard case because of airport handle horror stories and looking specifically at the Thule bike bag which is $1000 and reportedly heavy. Anyone have this bag or would you recommend something else? Thanks!What ever you do donāt go the scicon aero comfort ,I had one of these for years without any dramas but I did add extra padding and it used to take me about 2hrs to wrap it all up and disassembled etc
These days bags get handled much rougher and I hear storyās constantly of damadge bikes coming out of scicon bike bags
Now I have a velovault and it takes about 15 mins to put bike on and itās a hard case so nothing gunna happen to it
I have the Scicon hard case. I've used it for a few trips without issue. There is plenty of room in the case, but the basebar for tri bike needs to be taken off. I wrap the whole bike in pipe foam insulation, which did the job when needed. Having to take the basebar off can be an issue depending on the bike brand. If I had to do it again, I'd probably get the Bike Box Allen.
Coaching: https://bybtricoaching.com/ - accepting athletes for 2023
Eric and Paula on the TTL podcast both said they have this case (not sponsored) and gave very good reviews.
https://evocsports.us/.../road-bike-bag-pro-1
"I drank what?!?!" - Socrates
Poor Swimmer. Weak Cyclist. Slow Runner.
TriDot Ambassador / Sacramento Triathlon Club
if your bike is 54cm or smaller, i have been very happy with the trico iron case
Cardboard rules!!
Re: Bike travel case [BigBoyND]
BigBoyND wrote:
If you want to avoid disassembling the front: BBAlan Easyfit or Premier Bike If you'd prefer disassembly and having a smaller case as a result: VeloVault
I have the premier case and I advise against it. Iāve flown with it for 7 or 8 races and the zipper is shot. I have a medium speed concept and the fit is WAY too tight on the basebar and causes the zipper to split. Itās going to cost $600+ dollars for a new zipper.
Get the BBA.
@floathammerholdon | @partners_in_tri
Re: Bike travel case [cloy]
How wide is that basebar? Would the zipper be fine if your bar wasn't too wide for the case?
The BBA certainly has more room and doesn't even require the extensions or seatpost to be removed. Tradeoff is the case size.
Has anyone used the Canyon case? It has a soft shell but there is a full metal frame and metal(?) plates in certain areas. It also looks to fit bikes with extensions in place. At 600ā¬, it's also much cheaper than the 875ā¬ evoc or BBA.
I think that the case would be fine with more narrow basebars, yes. I think mine are 42cm, so maybe 40cm would be passable.
Re: Bike travel case [weakandpuny]
weakandpuny wrote:
Eric and Paula on the TTL podcast both said they have this case (not sponsored) and gave very good reviews. https://evocsports.us/.../road-bike-bag-pro-1
I recommend the Bike Box Allen Aero Easy fit. I ordered mine before the race I just did this past Sunday. In fact I'm flying home with bike tomorrow. I had the first Bike Box Allen and had to take apart the bike when I flew with it in the past. Was a huge pain for my husband. The new Aero Easy fit is great. Just take off the wheels and pedals. It made it from Burlington VT Int'l airport to JFK to San Diego fine. No problems with bike. Tip: always ask the airline person checking your bike in for a fragile sticker for both sides of the case.
I don't know if there is a hard case where you can leave your headset on and not have to take apart your bike aside from the new BBA aero easy fit. I will say I paid the approx $350 FedEx fee to get it to my house from the UK before the race. Still worth it.
Death is easy....peaceful. Life is harder.
Re: Bike travel case [Triingtotrain]
Thanks everyone. Looks like it's between BBA and the Evoc bag. Love how only the pedals and wheels have to be removed for both, but I wonder if the BBA isn't more protective with it's complete hardshell cover vs. the Evoc which relies on struts to support certain areas of the bike but not the whole bike itself. Pricing is similar because of the shipping costs of BBA to the U.S. I'm leaning towards the BBA although the lightweight aspects of the other bag are attractive.
TriSi wrote:
Thanks everyone. Looks like it's between BBA and the Evoc bag. Love how only the pedals and wheels have to be removed for both, but I wonder if the BBA isn't more protective with it's complete hardshell cover vs. the Evoc which relies on struts to support certain areas of the bike but not the whole bike itself. Pricing is similar because of the shipping costs of BBA to the U.S. I'm leaning towards the BBA although the lightweight aspects of the other bag are attractive.I only paid the FedEX 1-3 days (ended up more like 5 or 6 days) $350 USD (around 300 pounds) because I needed the new case for a race. I hadn't realized BBA made a new case until a few weeks before I had to fly to my race. I am not sure but if you get regular shipping, it's maybe around $100, but definitely not $350!! It comes from the UK so will take a few weeks.
Triingtotrain wrote:
Shipping to the U.S. is 250 Pounds or $304 USD. Itās 5-9 days via FedEx.
Re: Bike travel case [Bryan!]
I thought there was a cheaper shipping option. Still worth it.
I thought there was a cheaper shipping option. Still worth it.That is the cheapest option. The only other option is FedEx priority in 1-3 days and thatās 300 pounds or $365 USD.
TriSi wrote:
Thanks everyone. Looks like it's between BBA and the Evoc bag. Love how only the pedals and wheels have to be removed for both, but I wonder if the BBA isn't more protective with it's complete hardshell cover vs. the Evoc which relies on struts to support certain areas of the bike but not the whole bike itself. Pricing is similar because of the shipping costs of BBA to the U.S. I'm leaning towards the BBA although the lightweight aspects of the other bag are attractive.BBA has insane shipping charges since Covid. And you may get hit by customs.
If you're considering Evoc, look at Canyon. They have some videos showing how it comes together. The interior compartments are smart and it has protective struts and plates like the Evoc. But for much less. And if you won't use it for a while, it can be partially disassembled to take up less space in the basement.
So i think Iām settle upon the BBA and I thank you all for your input. One thing for those who have this- does it take up a huge amount of space at home? I live in a 1 bedroom in white plains, ny š
Fill it up with summer clothes in the winter and winter clothes in the summer - problem of space solved!
Nice! The ideas and innovation here are second to none! :)
