Long time ST lurker here with a question & an idea…
I’ve been looking for the fastest tire to try and optimize my 40k time.
Has there been any further CRR data on the Veloflex Record vs Corsa Speed 2, since Aerocoach and BRR posted conflicting results?
BRR:
7.3 watts per tire with latex tubes, 120 psi,
94 lbs load
Also 11.4 watts at a more realistic 80psi, using less realistic butyl tubes
https://www.bicyclerollingresistance.com/...iews/veloflex-record
7.0 watts for 25mm version, latex tube
8.4 watts for butyl tubes, 80psi
https://www.bicyclerollingresistance.com/...toria-corsa-speed-g2
Aerocoach:
Records are 16.5w
23mm Corsa Speed 2 is 21.4w.
Tested at 27mph
https://www.aero-coach.co.uk/...ling-resistance-data
I’ll link to the larger discussion on this, but I don’t think any reason for the difference was resolved:
https://forum.slowtwitch.com/...a_Speeds_P7339645-4/
I have a pair of both tires in 23mm and have a great spot where I’ve been doing Chung testing for the post year. I was thinking about doing a test to compare CRR of these.
The .5 mile stretch of road with hills at either end has a variety of different road surfaces. Not awful, but lot clean either.
It would be a pain in the butt to do this test. I’d have to switch tires in between runs, probably multiple times, and also do all the things necessary to get a high precision Chung run:
- windless day
- super consistent position
- ride the same path over the pavement every time
I’d also have to confirm tire width & profile are similar… I recall a comment on Slowtwitch (maybe Xav?) that these tires had similar widths & profiles, though I can’t find it now… I’d have to measure, but assuming the widths are close I’d call this a wash… and fast/slow runs should help to see out any significant changes in CdA.
With all that said, I’ve been Chung’ing a good bit, and when everything is right I can be reliably consistent runs to capture differences of .002 CdA, or less than 2 watts at 25mph.
I’ve read the idea that that real road conditions amply tested CRRs from BRR around 30%. And I’ve done basic lo-fi Chung testing that supports this (I measured 23mm GP5000 to be .380 at 80psi, vs. .321 from BRR). So if the real world difference between the tires is anything remotely like Aerocoach measured, +20 to 30 percent, then I should definitely be able to see it, even with the challenges above.
Especially if I do both fast & slow runs to separate out CdA and CRR.
This answer is a big deal, I think, since we’re talking about the “fastest” road tire. And because people like me are spending time, money, and risking flats to ride the Veloflex when there are conflicted results about the benefits.
Looking for feedback from the community on the proposed test. And also if more data on the tires is available that I’ve totally missed. There’s other stuff I’d rather do if this isn’t necessary!
If I end up doing the test and get something usable, I’ll post the results here as a new data point on these tires.
BRR:
94 lbs load
Aerocoach:
Records are 16.5w
Tested at 27mph
- windless day
Audioslave784: May 10, 22 4:34
