Picked up a FC-R7000 160mm crankset as a cheap(ish) way to try a shorter crank arm length on my 2016 P2 that came with a FSA Gossamer crank. Both are listed as having 24mm spindle diameters. Is this as simple as swapping the cranksets or does it require the wheelsmfg BBright adaptor/shim set? If it needs the adaptor how difficult is it to get everything perfect?
Re: Cervlo P2 FSA to FC-R7000 Crankset Swap [OV105mover]
Pretty sure it's just a straight swap
I think your P2 came with a pressfit 30 crank and a shimano will be a 24mm
I would recommend you get the Wheels manufacturing Threaded BB for 24mm axles
https://wheelsmfg.com/...no-cranks-black.html
Edit: If it did come with a 24mm crank then it should be a direct swap.
I put that crank on my IA16, I'm still not sold on the shorter cranks but I'm giving it a good chance. Probably use it the whole season and then evaluate performance.
Re: Cervlo P2 FSA to FC-R7000 Crankset Swap [jaretj]
Follow up if anyone has a similar interest...Jaretj is correct...FSA Gossamer Crank that came on my 2016 P2 has a 30mm dia spindle. LBS is doing the swap and installing a Wheels Mfg Shimano Hollowtech II 24mm dia angular contact BB. Another knowledgeable slowtwitcher...
Glad it worked out for you. Let us know how the 160 feels.
What crank length are you trying?
Re: Cervlo P2 FSA to FC-R7000 Crankset Swap [jimatbeyond]
160mm. Recently moved from 165mm to 160mm crank arms on my Cervelo P3C that lives on the Kicker Core. I'm 5’6” (on a good day) and although this is a small change it’s helped my breathing when riding on the aero bars . Picking up my P3 today after my LBS installed a 160mm crankset (same as the one one the P3C - Shimano 105 FC-R7000) and Wheels Mfg BB..
I was actually asking jaretj what crank length they were trying.
At 5'6", I would think that you would want to be on 150mm cranks.
My 16 year old son is 5'11" and he uses 155mm.
I'm currently on a 160 crank
