Hi all,
I have decided to take the plunge and change my race setup for the remainder of the year. For whatever reason I have always run Butyl tubes and 23c GP4000s, pumped to 120PSI (i weigh 87kg, 191lbs). Ive always done it, whether it be my road bike or TT. It would appear im losing valuable time, so I figured I'd take the plunge into latex but am curious as to what pressures I should run and what latex tubes will work with a FFWD disc and 90mm front, noting I will need some value extenders (removable or screw in).
Current thinking is to switch to Michelin Air Comp Latex after applying some tubeless rim tape. Pair it with some new 5000s.
I'd value any thoughts you may have :)
