Power2Max makes an
NGeco spider for 3-bolt-spider SRAM cranks for $490. Probably need to spring the extra $100 for the optional Praxis Chainrings, too, as I don't think that spider works with Force 22's "hidden bolt" design.
https://power2max.cc/.../products/ngeco-sram Or ditch the Force crank set and get a set of the 8-bolt-spider carbon
Quarq DZero Dub cranks ($196) that go with the spider you linked. Again, you'll need to add for chain rings as they're not included.
Or you can scrounge for an older, 3-bolt style Quarq Dzero PM. Spiders alone are hard to find, but you can still find the alloy-arm/PM-spider combos for fairly cheap, and swap over the spider to your carbon Force 22 crank arms.
R&A has what appears to be the correct one for $550. You can maybe even recoup a few shillings by putting your non-power spider on the alloy arms and selling the resulting mongrel remnants on ebay or elsewhere.
