I thought you said the Annointed One had delivered us from the recession? I thought you said The One had turned around the economy? I thought you said The Chosen One had implemented policies to save us all?
What happened?
Fail ...
WASHINGTON (AP) -- The number of newly laid-off workers seeking unemployment benefits rose last week, a sign that jobs remain scarce even as the economy recovers.
The increase also may result from the difficulty the Labor Department has in seasonally adjusting the claims around the Easter holiday, which falls on different weeks each year.
"This is ... a volatile time when the numbers move around quite a bit," a department analyst said.
The Labor Department said Thursday that first-time claims increased by 18,000 in the week ended April 3, to a seasonally adjusted 460,000. That's worse than economists' estimates of a drop to 435,000, according to a survey by Thomson Reuters.
http://finance.yahoo.com/...92.html?x=0&.v=7
If there are no dogs in Heaven, then when I die I want to go where they went. - Will Rogers
Emery's Third Coast Triathlon | Tri Wisconsin Triathlon Team | Push Endurance | GLWR
What happened?
Fail ...
