the handoff!
to your point, and just per my intuition, it seemed to me that if the virus is embedded in droplets - which is what I've been reading - that it's the airborn or surfacebound droplets that carry the virus payload. the N95 filter is for particles that are airborn, rather than traveling the galaxy inside a little spaceship of water.
if you are infected, and the mask keeps the droplets from disbursing into the atmosphere through your cannon of a sneeze or cough, good. if the mask keeps an incoming droplet from making its way past layers of fabric, also okay.
i could imagine a droplet drying. leaving viruses on the outside layer. and now the virus isn't in a droplet spaceship. now the virus is a little spacewalker, which is small enough to move past the layers of fabric as you're sucking in oxygen. that's a problem, perhaps.
so i'm intrigued by the concept of a pocket, inside of which you'd place a filter. sort of like your coffee machine. the grounds stay out. the water moves through the filter.
in this case, what's needed is the material for the filter, so that when you suck in air, you aren't sucking in little spacewalkers.
in my mind's eye, i see a test. the sort of test they'd do in a village in the jungle, where you have no high tech lab. in this test you'd place a semi-permeable membrane - the filter - and you'd try to move very small molecules, not viscous, with low or no surface tension, through a filter. is there a fluid that would act as a proxy for a virus? place the fabric, paper, whatever the filter is, in a collander, pour that fluid overtop, see if it makes it through the filter.
if that won't work, then i'd go to work rigging up a test that uses gas instead.
and with that, help, folks! emilio has been making facemasks since, oh, monday or tuesday. 3M has been at it a little longer. i'm pretty sure he'd love to have the brainstorming crowdsourced.
Dan Empfield
aka Slowman
Dan Empfield
aka Slowman
