If I'm in the middle of a workout, can I zip back to the watch function to check the time?
Re: 920xt switch to time of day during activities? [jroden]
Set up a data screen with time of day and you’ll be able to scroll to it.
Trust me I’m a doctor!
Well, I have a PhD :-)
Re: 920xt switch to time of day during activities? [PhilipShambrook]
Do I need to do that for each activity type? I wish I could delete activities o never do.
jroden wrote:
Do I need to do that for each activity type? I wish I could delete activities o never do.Go to Settings, Activity Profiles, select the profile "e.g. Duathlon", then select Remove Profile. That will delete the profiles you don't need.
Yes, when you set the data screens that is per Activity Profile. Go to Data Screen, scroll down to Clock and select to turn it from Off to On.
Hope that helps.
I miss you "Sports Night"
jroden wrote:
Do I need to do that for each activity type? I wish I could delete activities o never do.Yes.
I miss the 910XT method of displaying time. Going to status screen (single button press from any other screen) gave us a little clock at the bottom of the display.
Re: 920xt switch to time of day during activities? [Quo Vadimus]
Thank you that worked perfectly.
Re: 920xt switch to time of day during activities? [Dilbert]
Long time since I had a 920 but I believe you can include a data field with time of day. I usually have 1 data screen with Distance, Time, HR, Speed/Pace, then another with Distance, Time of Day, HR zone, Avg speed/space.
I think you can set up the 920 similarly.
jroden wrote:
If I'm in the middle of a workout, can I zip back to the watch function to check the time?If you hit the lower left side button (3 dots) during a workout, the activity profile screen will come up with the time at the upper right, then hit enter or back to return to the workout
"I'm thinking of a number between 1 and 10, and I don't know why!"
Yep, this is what I do
