I'm following a TR base building plan and noticing that my heart rate rarely gets above low 90's during any of the workouts. They feel difficult from a muscular standpoint but not aerobically. My legs are always spent by the end but my HR is nowhere near a typical road ride, where I'd normally average in the 120's or higher. Does it seem normal/beneficial to be staying in Z1 during these workouts?
Re: Where is your HR during sweet spot workouts? [Dgconner154]
That seems incredibly low in terms of HR. For sweet spot my HR is generally in the 145-155 range. Threshold stuff is 160's to close to 170 and VO2 max is a bit higher than that. For a HIM my HR avg is generally around 150 at an 80% effort.
Coaching: https://bybtricoaching.com/ - accepting athletes for 2023
Re: Where is your HR during sweet spot workouts? [natethomas]
Ditto... though if Im doing low cadence work (45-55 rpm) Im probably 5-7 bpm lower, but by ranges match nates almost exactly
I just finished SSB1 HV and for Galena +3 my HR was consistently averaging 154bpm over the 20min intervals at 90%, a little lower than it had been earlier in the week and over long durations (was averaging 158 previously) so I'm bumping myself up 10w next week and see how that goes for SSB2, and my threshold HR tends to reside 167-168, so I guess my HR is 158-163 when I'm less acclimated and mid 150's when I'm in good shape
What equipment are you using?
I would definitely question your hardware. That doesn't seem possible or accurate.
- Jordan
My Strava
- Jordan
My Strava
Re: Where is your HR during sweet spot workouts? [Masnart]
Masnart wrote:
I would definitely question your hardware. That doesn't seem possible or accurate.This.
Yeah that's what I was thinking, must be bad readings from my watch.
For reference I averaged 139bpm during the bike of my last 70.3 and 152bpm in my most recent Oly.
I'm using a Fenix 5 but haven't actually been recording my TR workouts with my watch, just glancing at my heart rate periodically. I'm not sure why that would make a difference but I'll try recording my next ride with the watch and see if it's better.
Thanks all.
Thanks all.
For me Sweet Spot HR is around 80% of HR Max (so around 145-150 BPM).
Base endurance is around 60/65 % of Max HR (so around 110-120 BPM).
Lowering rpm slightly reduce the bpm, but not to 90...
Dgconner154 wrote:
Yeah that's what I was thinking, must be bad readings from my watch. I'm using a Fenix 5 but haven't actually been recording my TR workouts with my watch, just glancing at my heart rate periodically. I'm not sure why that would make a difference but I'll try recording my next ride with the watch and see if it's better.
Thanks all.
The OHR LED's shine less brightly during 24/7 monitoring than they do during an activity. If you want accurate HR during intensity, definitely record an activity.
Ohr doesn't work graat for everyone... And sometimes placement and tightness are crucial to get it right. Operating in 24/7 mode won't help that.
Definitely use workout mode.
Sweet spot should be somewhere between your HIM and OD hr, but closer to your OD.
Re: Where is your HR during sweet spot workouts? [mcalista]
Interesting. Would the Broadcast HR mode act the same as an active activity or the low-energy 24/7 monitoring?
Re: Where is your HR during sweet spot workouts? [mgreer]
Broadcast mode follows whatever setting you are in. You can broadcast During Activity, or Not During Activity.
Hmm, guess I'll have to play around with it. I use the "Broadcast HR" from the controls menu, so not starting an activity, but it is a distinct mode of operation.
mcalista wrote:
Thanks all.
Good to know, thanks!
Ran my Fenix in Indoor Cycling mode tonight and averaged 126 but more like high 130's during the sweet spot intervals. Seems more reasonable. Crazy that there is such a difference running it in activity mode.
Sweet Spot is around :
Power : 90% of FTP / MLSS / Threshold power
HR : 80% of max HR
Logically, several peoples indicated HR around 145 / 150 / 155 bpm
130 is probably a bit low, except if your MaxHR is very low.
Sweet Spot optimal cadence is around 90 / 95 rpm (people dependent, of course)
HR : 80% of max HR
Dgconner154 wrote:
I'm following a TR base building plan and noticing that my heart rate rarely gets above low 90's during any of the workouts. They feel difficult from a muscular standpoint but not aerobically. My legs are always spent by the end but my HR is nowhere near a typical road ride, where I'd normally average in the 120's or higher. Does it seem normal/beneficial to be staying in Z1 during these workouts?Yeh that's just bananas.
For me there's no question that my hr is subtly less indoors than outdoors for the same muscular leg effort.
But then outside i'm using more muscles to stabilise the bike and just the extra brain power of thinking about the road the traffic etc will have a metabolic cost.
My max is 175 and my LT1 is 130 and threshold 155 - 162. After 162 I know i'm living on borrowed time ie a few small blasts up a climb or final mile push to the line.
For SS workouts my hr would usually be 140-145 on the trainer and maybe 145-150 on the road.
I'm thinking your OHR is picking up your cadence, mine does. Workout mode & making sure your band is snug may help.
80-85% max HR is where I average for sweet spot cycling workouts. Your monitor is way off.
Re: Where is your HR during sweet spot workouts? [dangle]
x2 on both points.
I don't understand it but I've quit using my Fenix 5 OHR during activities completely. It works fine if I'm not doing something but it is not reliable at all when I'm actually working out. I have 2 or 3 other monitors that work just fine and I've been using HRM's since the mid 90's, I like the Fenix but it doesn't provide me with useful HR during training.
20 or so beats off during a run would be common from when I've tried it. Anytime I not that it has received a software update I try it again. I don't think it is just my skin tone or something along those lines either as I'm generally fine using a Scoche monitor.
I just pair mine with a chest strap and with that, it gets good trustworthy numbers. Otherwise it starts to get wonky as soon as I sweat hard
