longtrousers wrote:
Two points I want to share with you: 1. batteries
I had an annoying experience at a check-in counter of Condor (a European airline) As I run Campagnolo ESP they did not like the battery. In the end I was lucky and they let it through.
After some research I found out that in principle you are not allowed to have any batteries in checked in luggage I think with any airline. You can take it in hand luggage if the capacity is <100 Wh, which is generally the case for such batteries.
With Campagnolo it is difficult to demount the battery. Although my trip this week to Kona is with Lufthansa and United I will demount the battery and mount it again in Kona anyway because I want to avoid any problems beforehand.
2. stem
I demount the stem from the fork to fold the cockpit such over the frame that it fits in my bike case, leaving all the cables. If you do not secure the fork-bearings the bearing balls can fall all over the place. A friend of mine had that-> he could not ride the bike when he arrived and tried to mount the stem again.
What I do is mount a dummy stem for travel such that the fork bearings stay in a defined state.
Does this apply to Di2 batteries as well? If so I can return my Orucase as I'll never be able to use it.
To breathe, to feel, to know I'm alive.
