I am listing a Sram Quarq Cinqo power meter. I bought it in 2013 and used it for Ironman. Sold my bike and it sat until 2016 when I did Ironman again. It has not been used since.
I am listing it with your choice of crank arms. Either the original set of S975 Sram crank arms that simply say Sram on them. The S975 are 9.5/10 condition. About perfect with no marks on them. Or, a new set of Sram Red crank arms. Both crank arms are 172.5mm.
The quarq has 10 speed sram rings on it 50/34
The quarq is a 110bcd bolt pattern for chainrings
I will mount the Quarq spider to the crank arms after the winning bidder tells me which crank arms you want. I will use the proper Loctite assembly compound Sram uses when mounting the spider to the arms.
Ebay style rules-
Biding starts at $100
Simply reply with your name and Bid amount
Bidding will end on Sunday, Feb 24 at 7:00pm Central time. To avoid last minute bidding, the winning bid must have a time stamp of 5 min after the last bid. So, a bid AFTER 7:00pm will be allowed as long as it is within 5 min of the last bid PRIOR to 7:00pm
I really want this to go to a STer and not Ebay, so hopefully someone gets a good deal and we can have some fun with this!
Ebay style rules-
