I am swapping from a Large Shiv to a Medium Dimond Marquise and I wasn't sure what fit numbers would be the same since the geometry of the bikes are a bit different. While I do plan to get a more turned in fit, I'd like to get the dimond setup as close to possible then go for changes from that position.
Can anyone help?
Fit numbers:
Thanks in advance for the help!
Can anyone help?
- are my stack/reach numbers just transferable?
- what about saddle height and offset from the BB center?
- any thing else that I need to consider?
Fit numbers:
- Stack: 650
- Reach: 510
- Crank Arm length: 165mm
- Saddle Height from BB center to saddle center: 78.5cm
- Saddle tip set back: 3cm
- The seat tube angle on the Shiv is 77 degrees vs. 79 degrees on the dimond.
