Runguy wrote:
I guess I fall into the "denier" label. From all the stuff I have read the problem (if there is one) are in the climate models that are used to project 100 years into the future. They seem weighted heavy in terms of CO2 impact and less so for clouds , solar flare, earth's position, etc. Not to mention how the historical data has been revised to the point the "pause" has now been corrected to a slight uptick in temps for the past 20 years or so. I just think there is more for us to learn and that as Duffy said spending lots of money that may not even address the problem is just wrong headed. Not to mention the increased cost of living if we try to artificially introduce more expensive alternate energy (sun, wind) in lieu of the economy will naturally do in time.
The above indicates that you have not made an effort to learn about the actual science behind the consensus on man-made climate change. Pretty much everything you say above is wrong.
You can start here for a layman's description. If you want to understand why your arguments are wrong, you can try here. I commend you on your journey to learn more.
"Go yell at an M&M"
