dunno wrote:
You would think if this were true (that the Chinese wheels are so bad) there would be tons of horror stories on the net-I cant find any??
Your post is a perfect example of what I'm talking about. Every time Chinese knockoffs are brought up, inevitably those for (and against) them create a false choice - normal function or complete failure. That's a pretty low bar for success if one deems Chinese wheels sufficient simply because "I have been riding them for years and they haven't failed".
The fact is, most riders aren't putting very much stress on their wheels. They don't ride fast enough, brake enough, descend enough, or stress the wheel enough to approach conditions where wheels might fail. And as others have posted on the thread, buying Zipp (or whoever else) doesn't make you immune to wheel failure.
But the statement I objected to was about performance, not safety. And in my limited experience, we tested a Chinese Zipp knockoff (40 to 50-ish mm depth) in the wind tunnel and found it performed worse than even stock options such as the Mavic Aksium. Undoubtedly, considering there are hundreds of knockoff options, it's likely at least a few test welll. And it's possible we just happened to test the one wheel that sucked.
But to believe that knockoffs provide 99% of the performance is to believe that the entire wheel manufacturing business, a business that employs very smart engineers who work very hard to improve performance, reliability, and aerodynamics, is a scam. I believe that is simply not the case.
Trent Nix
Owned and operated Tri Shop
F.I.S.T. Advanced Certified Fitter | Retul Master Certified Fitter (back when those were things)
