Hi there,
I've been trying to work on the optimal fit on my IA16 and I'm looking for advice on where to go from here.
I started with the standard felt setup and added zipp evo 70's to get a bit of hand rise for comfort. I had no additional risers on the bars at this point and it was as low as it could go (apart from underbar mounts), Adamo attack sadde.
Since then I've made a few changes, swapped out the bars to PD Aeria Ultimate (currently running 20mm spacers) and swapped to a Dash saddle.
Are there any recommendations on where to go from here? (kit choice aswell)
I can go one hole closer on the pads which could help bring elbows in, and remove the 20mm spacers if it would help.
Any thoughts and advice welcome!
Paul
Paul
