As the gluing tape acts as an additional cushioning element, it affects the rolling resistance of the wheel.
Results we got from the Wheel Energy Laboratory show an higher power absorption - given the same wheel, tubular, inflating pressure, testing machine, load and testing temperature - using Carogna tape (or other competitors' tapes) compared to mastics (any mastic, as differences between mastics are neglectable in terms of rolling resistance).
To talk about numbers:
a Vittoria Triathlon tubular 22 mm absorbs 32,8 W at 40 km/h and 9 bar when glued with mastic, while it absorbs 39,1 W when glued with Carogna tape (same conditions).
It's 6,3 W, a 20% difference that is mantained reducing the inflating pressure.
At 6 bar, the power absorption becomes 37,1 W for mastic, 44,6 W for Carogna, 7,5 W of difference.
Is this an acceptable penalty to pay for convenience of use?
Each one has his/her answer to that, and is obviously correct whatever it is, depending on the specific goals.
