I posted several power files that blow HR out of the water. How to you account for HR drift? Positive drift? What about negative drift like I see in most of my races? Because HR is elevated from the swim and the shift from being horizontal to vertical. Maybe I swim really hard, but again I've seen it take 30 minutes to slowly drop.
Lets look at what heart rate is for a second....
Your heart a positive displacement pump....though it's imperfect since the valves are just check valves, not positively engaged. Also, the chambers are not emptied completely so it's stroke volume can vary a little so its' "pump curve" in not linear because of this. That aside, even if flow rate was always directly proportional and linear, increase flow rate will increase the
potential for higher oxygen consumption, but will not measure it. Couple issues:
Your whole cardio system is not actively controlled by you brain. It's a passive response to chemical triggers. Some triggers can include things not related oxygen consumption.
There are other muscle efficiency factors going on at different intensities. That part of why power and HR zones are used. But these zones will vary day to day just as your FTP will vary.
No system is perfect. All data has value (pace, HR, power) but I just can't place HR above power as it varies so dramatically in varying situations.
Power is a direct measurement of the force generated by your muscles over a given time period. HR doesn't determine how hard you push on the pedals. Even if you were to connect an inline blood monitor that lets say oxygen, CO2 and lactate levels, it still won't tell you how hard your pushing on the pedals at that moment. It's still indirect.
TrainingBible Coaching
http://www.trainingbible.com
