Selling these for a friend of mine. He takes meticulous care of his kit so these things are mint. If you have any questions its easiest to contact him via email at hdiamond@webservicesus.com or PM me. Here's the low down on these awesome wheels:
ENVE 45 / PowerTap Carbon Clincher Wheelset: $1750.00
If you're going to own one wheel set for racing and training, this is it. These wheels have it all - aerodynamics, stiffness, low weight and durability. ENVE's 45 clincher is an excellent all-purpose rim, ideal for everyday training as well as uncompromised race day use. The rear wheel only has about 1000 miles on it and the front wheel has never been used – it is brand new.
The ENVE 45 clincher rim was designed with a 45mm rim profile to optimize aerodynamics while reducing rim weight to a mere 440g. The carbon braking surface was designed to minimize and dissipate heat, while providing a considerably lighter rim than those with traditional alloy braking surfaces. ENVE's proprietary molding process creates a spoke interface that permits higher tensions than most other carbon rims. This design dramatically improves nipple seating angles, which extends spoke fatigue life and wheel durability.
· Optimized for aerodynamics and ideal handling in all conditions
· DT Swiss Aerolite spokes
· 1,584 grams for the wheelset
Notes on pictures… front wheel has ENVE rim tape / rear Cyclops Powertap wheel has Cyclops rim tape -
- Includes Front & Rear Wheels / Skewers / Powertap hub tool / five (5) pair of NEW in the plastic bag brake pads
- Cyclops PowerTap G3 rear hub; Cyclops Powertap front
- Rim weight: 440g ea./ depth: 45mm / width: 21.6mm
- Hole count: 20 front, 24 rear / Rim
- Use with any ANT+ bike computer (Garmin , Catlike , iPhone , etc.). Easily swap to multiple bikes and a great alternative to a Quarq or SRM Power Meter.
