I have started riding my road bike on a new trainer in the basement to get through the winter. On a quality bike (I ride a Cervelo) - does using it locked in the trainer have any detrimental effects on the natural flex of the frame when riding in the trainer as opposed to the way the bike was designed to be ridden - on the road? It would seem to me that it might impact the frame stiffness or shape.
Re: Bike Damage in Trainer? [cowtippers]
Myth. Unless you're doing something really strange to it.
Quid quid latine dictum sit altum videtur
(That which is said in Latin sounds profound)
Re: Bike Damage in Trainer? [Titan]
I asssume that a trainer wouldn't put any unexpected pressure on carbon stays?
Re: Bike Damage in Trainer? [rundhc]
If your trainer clamps the skewer, and not the stays: no.
You should also ask about over tightening, the vice, and, I would loosen the press-on force--I believe that I bent my "whatever it is called" that the skewer goes through, by roughly removing the bike from the stand. (aluminum)
I did a post similar to yours a few weeks ago. The replies that I received (from guys like Tom D) said that if is virtually impossible to damage a frame in a trainer. I also have a Cervelo P3 and I was told the stress testing that they do on the bike far exceeds what you could ever do to it in a trainer.
Cowtippers..I would be more concerned about breaking the trainer. I have claim to that one (twice now). Busted some plastic piece that can't be replaced. Bike never had a problem, still questioning what in the World I have done. I rode close to a minimum of 10 hrs a week on the trainer for the past 2 yrs. No problems with the bike except one slow rider. No clue if riding the trainer adversly affected my speed, or I have just become lazy. I wouldn't worry about the bike if it is set on there correctly.
it is possible, because you will fix the bike where the bike is not fixed on the road. the contribution of loadings and stresses are different. the rear ends are not designed for trainers. rollers from TACX, like the SPORTTRACK, prevent this. You will find it on the tacxwebpage.
I don't know about really strange, but my rear wheel has gone out of round and I'm pretty sure the flywheel is not to tight.
J
J
Re: Bike Damage in Trainer? [JohnG]
JG wrote: ...my rear wheel has gone out of round...
That's not a trainer problem, that's a wheel problem...what is the proposed mechanism of damage to your wheel?
I'm not an expert, having only seen my trainer stuff with about 5-6 other people's trainers...total history of maybe 20 bikes and 30 wheels. But, take someone like Tom D., who rides on a trainer, personally sees lots of others that ride them, and has scads of customers who ride them: when Tom says trainers don't cause problems to the bike (as long as they are used as designed), I believe him. Keep the sweat out of the headset and other crevices, keep the bike clean, etc. No problems from a trainer....
Very likely the problem is a crappy old wheel under stress. I'm not worried about it. My youngest son turns 16 tomorrow and my trainer bike is older than he is.
J
J
Yep, I bet you're right!
I work for Kinetic. There has never been a reported incidence of any bike being damaged in any trainer that I am aware of. If it happened in ours, we'd fix it, and if it happened in someone else's trainer, I'd use it to sell ours.
