compliance is in the terminus of the blades, if the blade is raked. if the blade is straight, then the bending moment of the fork is shifted to the steerer
This isn't true for monocoque carbon forks that can be laid up to be compliant in one direction and appose twist in another regardless of blade shape. Carbon fishing poles are straight, they certainly have compliance. I can make a super strong and stiff steerer/crown lay up and "carbon fishing poles" for fork blades if I don't have to worry about cold-gluing or bonding the fork in pieces. If the fork is made in one mold you can do just about anything with it in terms of locating the compliance. Imagine a fork with "fishing pole" lay up on the front and back of the blade, but stiffer material used on the sides up near the cown. The bending would occur where the stiff lay up ended from the crown down regardless of blade shape.
Fork failures should not necessarily occur at the crown, this is one of the reasons for 1.5" or similar tapered sizes
-SD
https://www.kickstarter.com/...bike-for-the-new-era
