I'd like to drop my bars 10mm and have zero stack. LBS once said there has to be at least one spacer between the headset and stem, otherwise headset will be damaged. I fail to see the logic in that. So can I lose the spacer and mount the stem directly above the (integrated) headset?
Had lousy shifting running a 9-speed chain on a 9-speed cassette with new DA 7800 derailleur. Is a 10-speed chain the solution?
Much thanks.
Much thanks.
